주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon Echo Studio Subwoofer Replacement
필요한 것
  1. Amazon Echo Studio Subwoofer Replacement, Power Supply Board: 1 단계, 이미지 3개 중 1개 Amazon Echo Studio Subwoofer Replacement, Power Supply Board: 1 단계, 이미지 3개 중 2개 Amazon Echo Studio Subwoofer Replacement, Power Supply Board: 1 단계, 이미지 3개 중 3개
    • Flip the device upside down.
    • Pry up the edge of the rubber base panel with a spudger, then pull the rest of it off by hand.
    댓글 쓰기
  2. Amazon Echo Studio Subwoofer Replacement: 2 단계, 이미지 3개 중 1개 Amazon Echo Studio Subwoofer Replacement: 2 단계, 이미지 3개 중 2개 Amazon Echo Studio Subwoofer Replacement: 2 단계, 이미지 3개 중 3개
    • Use a T15 Torx screwdriver to remove the nine 3.2 mm screws.
    • Use a Torx T10 screwdriver to remove the six 2.7 mm screws.
    • After removing the screws, gently lift the base off, with care not to damage any of the connected cables.
    댓글 쓰기
  3. Amazon Echo Studio Subwoofer Replacement: 3 단계, 이미지 3개 중 1개 Amazon Echo Studio Subwoofer Replacement: 3 단계, 이미지 3개 중 2개 Amazon Echo Studio Subwoofer Replacement: 3 단계, 이미지 3개 중 3개
    • Before fully removing the base, remove the three attached connectors.
    댓글 쓰기
  4. Amazon Echo Studio Subwoofer Replacement: 4 단계, 이미지 2개 중 1개 Amazon Echo Studio Subwoofer Replacement: 4 단계, 이미지 2개 중 2개
    • Now unscrew the the single 10 mm Phillips screw.
    • Remove the power supply board.
    댓글 쓰기
  5. Amazon Echo Studio Subwoofer Replacement, Subwoofer: 5 단계, 이미지 1개 중 1개
    • Remove the two screws located across from each other on the outside of the plastic ring shown.
    • Remove the plastic outer ring that hugs the inside of the edges of the device.
    • This may require you to use a soft prying tool to separate it from the outer shell.
    댓글 쓰기
  6. Amazon Echo Studio Subwoofer Replacement: 6 단계, 이미지 3개 중 1개 Amazon Echo Studio Subwoofer Replacement: 6 단계, 이미지 3개 중 2개 Amazon Echo Studio Subwoofer Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the two 2.7 mm screws with a T10 Torx screwdriver.
    • Once the screws are removed, take the power supply's baseplate out of the unit.
    • You may need to gently pry the subwoofer's air ports from the round slots In the side of the unit.
    댓글 쓰기
  7. Amazon Echo Studio Subwoofer Replacement: 7 단계, 이미지 2개 중 1개 Amazon Echo Studio Subwoofer Replacement: 7 단계, 이미지 2개 중 2개
    • On the silver ring located on the outer edge of the plastic portion of the subwoofer, you will see four 2.7 mm screws. Use a Torx T10 screwdriver to remove them, in order to remove of the subwoofer.
    • Once the four screws have been removed, gently pull the subwoofer out as to not damage the wiring connecting the subwoofer to the main board inside the unit.
    • Follow the wires from the subwoofer to the main board and disconnect the connector attaching them.
    • Your subwoofer is now disconnected and ready to be replaced.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jaiden Wiles
회원 가입일: 10/26/22
178 평판
안내서 1개를 작성함
UMass Dartmouth, Team 2-6, Petersen Fall 2022 UMass Dartmouth, Team 2-6, Petersen Fall 2022 회원
UMASSD-PETERSEN-F22S2G6
4 회원들
안내서 13개를 작성함
1가이드 댓글
Does anybody know where to get a replacement subwoofer?
Matthew Johnson - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 15
지난 30일: 62
전체 시간: 1,626
