주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon Echo Studio Tweeter Replacement
필요한 것
    1. Amazon Echo Studio Tweeter Replacement, Power Supply Board: 1 단계, 이미지 3개 중 1개 Amazon Echo Studio Tweeter Replacement, Power Supply Board: 1 단계, 이미지 3개 중 2개 Amazon Echo Studio Tweeter Replacement, Power Supply Board: 1 단계, 이미지 3개 중 3개
      • Flip the device upside down.
      • Pry up the edge of the rubber base panel with a spudger, then pull the rest of it off by hand.
      댓글 쓰기
    2. Amazon Echo Studio Tweeter Replacement: 2 단계, 이미지 3개 중 1개 Amazon Echo Studio Tweeter Replacement: 2 단계, 이미지 3개 중 2개 Amazon Echo Studio Tweeter Replacement: 2 단계, 이미지 3개 중 3개
      • Use a T15 Torx screwdriver to remove the nine 3.2 mm screws.
      • Use a Torx T10 screwdriver to remove the six 2.7 mm screws.
      • After removing the screws, gently lift the base off, with care not to damage any of the connected cables.
      댓글 쓰기
    3. Amazon Echo Studio Tweeter Replacement: 3 단계, 이미지 3개 중 1개 Amazon Echo Studio Tweeter Replacement: 3 단계, 이미지 3개 중 2개 Amazon Echo Studio Tweeter Replacement: 3 단계, 이미지 3개 중 3개
      • Before fully removing the base, remove the three attached connectors.
      댓글 쓰기
    4. Amazon Echo Studio Tweeter Replacement: 4 단계, 이미지 2개 중 1개 Amazon Echo Studio Tweeter Replacement: 4 단계, 이미지 2개 중 2개
      • Now unscrew the the single 10 mm Phillips screw.
      • Remove the power supply board.
      댓글 쓰기
    1. Amazon Echo Studio Tweeter Replacement, Subwoofer: 5 단계, 이미지 1개 중 1개
      • Remove the two screws located across from each other on the outside of the plastic ring shown.
      • Remove the plastic outer ring that hugs the inside of the edges of the device.
      • This may require you to use a soft prying tool to separate it from the outer shell.
      댓글 쓰기
    2. Amazon Echo Studio Tweeter Replacement: 6 단계, 이미지 3개 중 1개 Amazon Echo Studio Tweeter Replacement: 6 단계, 이미지 3개 중 2개 Amazon Echo Studio Tweeter Replacement: 6 단계, 이미지 3개 중 3개
      • Remove the two 2.7 mm screws with a T10 Torx screwdriver.
      • Once the screws are removed, take the power supply's baseplate out of the unit.
      • You may need to gently pry the subwoofer's air ports from the round slots In the side of the unit.
      댓글 쓰기
    3. Amazon Echo Studio Tweeter Replacement: 7 단계, 이미지 2개 중 1개 Amazon Echo Studio Tweeter Replacement: 7 단계, 이미지 2개 중 2개
      • On the silver ring located on the outer edge of the plastic portion of the subwoofer, you will see four 2.7 mm screws. Use a Torx T10 screwdriver to remove them, in order to remove of the subwoofer.
      • Once the four screws have been removed, gently pull the subwoofer out as to not damage the wiring connecting the subwoofer to the main board inside the unit.
      • Follow the wires from the subwoofer to the main board and disconnect the connector attaching them.
      • Your subwoofer is now disconnected and ready to be replaced.
      댓글 쓰기
    1. Amazon Echo Studio Tweeter Replacement, Motherboard: 8 단계, 이미지 2개 중 1개 Amazon Echo Studio Tweeter Replacement, Motherboard: 8 단계, 이미지 2개 중 2개
      • Remove the thirteen 9 mm Phillips #00 screws.
      • Some screws may be hidden by other components; simply hold them out of your way during screw removal.
      댓글 쓰기
    2. Amazon Echo Studio Tweeter Replacement: 9 단계, 이미지 1개 중 1개
      • Unfasten the Phillips 9mm screws, using the Phillips #00 Screwdriver.
      • There may be obstruction against some screws, which can be avoided by using a spudger or your hand.
      댓글 쓰기
    3. Amazon Echo Studio Tweeter Replacement: 10 단계, 이미지 3개 중 1개 Amazon Echo Studio Tweeter Replacement: 10 단계, 이미지 3개 중 2개 Amazon Echo Studio Tweeter Replacement: 10 단계, 이미지 3개 중 3개
      • After removing the screws, locate the four power connectors on the motherboard and detach them from the motherboard.
      댓글 쓰기
    4. Amazon Echo Studio Tweeter Replacement: 11 단계, 이미지 1개 중 1개
      • Remove the motherboard from the device by pulling it out.
      • Be careful to not damage any of the loose wires inside the case while removing the motherboard.
      댓글 쓰기
    1. Amazon Echo Studio Tweeter Replacement, Light Board: 12 단계, 이미지 3개 중 1개 Amazon Echo Studio Tweeter Replacement, Light Board: 12 단계, 이미지 3개 중 2개 Amazon Echo Studio Tweeter Replacement, Light Board: 12 단계, 이미지 3개 중 3개
      • First, locate the six 10 mm screws at the top of the inside of the shell and unscrew them with a T10 Torx screwdriver.
      • After removing the six screws from the inside, lift the top speaker cover.
      댓글 쓰기
    2. Amazon Echo Studio Tweeter Replacement: 13 단계, 이미지 3개 중 1개 Amazon Echo Studio Tweeter Replacement: 13 단계, 이미지 3개 중 2개 Amazon Echo Studio Tweeter Replacement: 13 단계, 이미지 3개 중 3개
      • Lift the top plastic cover that has the buttons.
      • If you feel a lot of resistance while removing this piece, check if you removed every screw from the inside or you risk breaking this part.
      댓글 쓰기
    3. Amazon Echo Studio Tweeter Replacement: 14 단계, 이미지 3개 중 1개 Amazon Echo Studio Tweeter Replacement: 14 단계, 이미지 3개 중 2개 Amazon Echo Studio Tweeter Replacement: 14 단계, 이미지 3개 중 3개
      • After the screws are removed, carefully lift the lightboard and disconnect the ribbon.
      • Make sure you do not forget to detach the ribbon from the shell, or you risk breaking it.
      댓글 쓰기
    1. Amazon Echo Studio Tweeter Replacement, Tweeter: 15 단계, 이미지 3개 중 1개 Amazon Echo Studio Tweeter Replacement, Tweeter: 15 단계, 이미지 3개 중 2개 Amazon Echo Studio Tweeter Replacement, Tweeter: 15 단계, 이미지 3개 중 3개
      • Remove the four 3.27 mm screws with T15 Torx driver.
      • After removing the screws, push/pull the inner shell out of the outer shell.
      • You might need someone's help to remove the inside shell, because it is very tight inside the outer shell.
      댓글 쓰기
    2. Amazon Echo Studio Tweeter Replacement: 16 단계, 이미지 3개 중 1개 Amazon Echo Studio Tweeter Replacement: 16 단계, 이미지 3개 중 2개 Amazon Echo Studio Tweeter Replacement: 16 단계, 이미지 3개 중 3개
      • Remove the wire from its slot inside the shell so the tweeter can be removed.
      • Unscrew the two 3.2 mm screws holding the tweeter in place with a T15 Torx screwdriver.
      • Pull the tweeter out.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Filipe Oliveira
회원 가입일: 10/26/22
339 평판
안내서 2개를 작성함
UMass Dartmouth, Team 2-6, Petersen Fall 2022 UMass Dartmouth, Team 2-6, Petersen Fall 2022 회원
UMASSD-PETERSEN-F22S2G6
4 회원들
안내서 19개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 26
전체 시간: 604
