주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon Echo Woofer Replacement
필요한 것
    1. Amazon Echo Woofer Replacement, Power and Speaker Driver Board: 1 단계, 이미지 1개 중 1개
      • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
      • Peel off the rubber footing from the bottom of the Echo.
      • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
      댓글 쓰기
    2. Amazon Echo Woofer Replacement: 2 단계, 이미지 3개 중 1개 Amazon Echo Woofer Replacement: 2 단계, 이미지 3개 중 2개 Amazon Echo Woofer Replacement: 2 단계, 이미지 3개 중 3개
      • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
      댓글 쓰기
    3. Amazon Echo Woofer Replacement: 3 단계, 이미지 1개 중 1개
      • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
      댓글 쓰기
    4. Amazon Echo Woofer Replacement: 4 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
      • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
      댓글 쓰기
    5. Amazon Echo Woofer Replacement: 5 단계, 이미지 2개 중 1개 Amazon Echo Woofer Replacement: 5 단계, 이미지 2개 중 2개
      • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
      • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
      댓글 쓰기
    6. Amazon Echo Woofer Replacement: 6 단계, 이미지 3개 중 1개 Amazon Echo Woofer Replacement: 6 단계, 이미지 3개 중 2개 Amazon Echo Woofer Replacement: 6 단계, 이미지 3개 중 3개
      • Using the spudger, pull back the two plastic clips on the plate.
      • Lift the board up and pull it away from the plate.
      댓글 쓰기
    1. Amazon Echo Woofer Replacement, Tweeter Assembly: 7 단계, 이미지 2개 중 1개 Amazon Echo Woofer Replacement, Tweeter Assembly: 7 단계, 이미지 2개 중 2개
      • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
      댓글 쓰기
    2. Amazon Echo Woofer Replacement: 8 단계, 이미지 1개 중 1개
      • Peel off the black fabric wrapped around the Echo.
      • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
      댓글 쓰기
    3. Amazon Echo Woofer Replacement: 9 단계, 이미지 3개 중 1개 Amazon Echo Woofer Replacement: 9 단계, 이미지 3개 중 2개 Amazon Echo Woofer Replacement: 9 단계, 이미지 3개 중 3개
      • Remove the four 42.8 mm T10 Torx screws around the tweeter.
      • Lift the tweeter and its attached housing from the device.
      댓글 쓰기
    1. Amazon Echo Woofer Replacement, Woofer: 10 단계, 이미지 1개 중 1개
      • Lift the woofer out of the Echo.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Alexander Albert
회원 가입일: 02/04/16
1,169 평판
안내서 6개를 작성함
USF Tampa, Team 3-3, Wollert Spring 2016 USF Tampa, Team 3-3, Wollert Spring 2016 회원
USFT-WOLLERT-S16S3G3
4 회원들
안내서 25개를 작성함
3가이드 댓글
Where can you buy a replacement woofer?
adam mierzwa - 답글 공유
My exact question.
Marty Koenig - 답글 공유
Could you post the dimension of the woofer unit? Its depth and diameter (and possibly screw holes location/diameter)? That would be very useful. Thank you.
No Body - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 45
전체 시간: 8,687
