주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon Fire 5th Generation Battery Replacement
필요한 것
    1. Amazon Fire 5th Generation Battery Replacement, Remove front screen assembly: 1 단계, 이미지 2개 중 1개 Amazon Fire 5th Generation Battery Replacement, Remove front screen assembly: 1 단계, 이미지 2개 중 2개
      • Ensure that your device is turned off.
      • Remove any micro-SD card that may be installed in the Fire. Failure to do so could damage the micro-SD card itself or the micro-SD card reader on the Fire.
      • Holding the Fire firmly, wedge a plastic opening tool into the crease on the edge of the device.
      • Slowly work the plastic opening tool around the device until the entire back cover releases from the front of the device.
      댓글 쓰기
    2. Amazon Fire 5th Generation Battery Replacement: 2 단계, 이미지 3개 중 1개 Amazon Fire 5th Generation Battery Replacement: 2 단계, 이미지 3개 중 2개 Amazon Fire 5th Generation Battery Replacement: 2 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      $3.99
      • Using angled ESD precision tweezers, lift up on the battery cables to separate the battery connector from its socket.
      • Be sure to lift the battery connector cables themselves and not the actual socket. Doing this step incorrectly could damage the connector.
      댓글 쓰기
    3. Amazon Fire 5th Generation Battery Replacement: 3 단계, 이미지 3개 중 1개 Amazon Fire 5th Generation Battery Replacement: 3 단계, 이미지 3개 중 2개 Amazon Fire 5th Generation Battery Replacement: 3 단계, 이미지 3개 중 3개
      • Carefully and slowly work a large plastic opening tool along the edge of the battery pack. Angle the tool to pry it up.
      • When you have successfully lifted the battery pack up on one side or corner, carefully wedge the opening tool under the pack about 1/2" and work around the rest of the sides.
      • Be careful not to bend the battery. Don't use too much force, as it can damage the battery.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 25명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Maximilian Plavcan
회원 가입일: 02/10/16
1,239 평판
안내서 2개를 작성함
USF Tampa, Team 1-2, Nance Spring 2016 USF Tampa, Team 1-2, Nance Spring 2016 회원
USFT-NANCE-S16S1G2
3 회원들
안내서 13개를 작성함
9가이드 댓글
Where do you purchase the replacement battery (and what part number)?
John LaRue - 답글 공유
Battery to buy right below!
https://www.ebay.com/itm/2980mAh-Battery...
Jorge Hurtado - 답글 공유
Thanks for this guide Maximilian, and also for the link to purchase the battery, commenter Jorge! Those batteries seem to be pretty difficult to find online. Amazon definitely doesn’t make it easy to find them even on their own site, though they seem happy to sell a replacement fire… :)
crimsontideaggie - 답글 공유
Update: I had to do two of these, and it didn’t take me any longer than 10 minutes for either one of them. Easy peasy, thanks for the clear and concise guide.
If the battery connector comes off does it need soldering back on
Ashley Pollen - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 39
지난 30일: 204
전체 시간: 26,664
