주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon Fire HD 10 Battery Replacement
필요한 것
    1. Amazon Fire HD 10 Battery Replacement, Screen: 1 단계, 이미지 3개 중 1개 Amazon Fire HD 10 Battery Replacement, Screen: 1 단계, 이미지 3개 중 2개 Amazon Fire HD 10 Battery Replacement, Screen: 1 단계, 이미지 3개 중 3개
      • Avoid prying near bottom right hand side due to LCD Connector
      • Use a plastic opening tool to pry the screen up in the right hand corner.
      댓글 쓰기
    2. Amazon Fire HD 10 Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Do not completely remove the screen yet as there is a ZIF connector connected.
      • Lift the screen and digitizer from the case.
      • You may need to use some force due to the glue.
      댓글 쓰기
    3. Amazon Fire HD 10 Battery Replacement: 3 단계, 이미지 2개 중 1개 Amazon Fire HD 10 Battery Replacement: 3 단계, 이미지 2개 중 2개
      • Be mindful of the ZIF connector.
      • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
      댓글 쓰기
    4. Amazon Fire HD 10 Battery Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the screen and digitizer from the case completely.
      댓글 쓰기
    1. Amazon Fire HD 10 Battery Replacement, Battery: 5 단계, 이미지 3개 중 1개 Amazon Fire HD 10 Battery Replacement, Battery: 5 단계, 이미지 3개 중 2개 Amazon Fire HD 10 Battery Replacement, Battery: 5 단계, 이미지 3개 중 3개
      • Locate the power cable that links the battery to the motherboard.
      • Carefully unplug the battery power cable to disconnect the battery from the motherboard.
      • The third image shows what it should look like with the battery power cable is disconnected.
      댓글 쓰기
    2. Amazon Fire HD 10 Battery Replacement: 6 단계, 이미지 3개 중 1개 Amazon Fire HD 10 Battery Replacement: 6 단계, 이미지 3개 중 2개 Amazon Fire HD 10 Battery Replacement: 6 단계, 이미지 3개 중 3개
      • Begin by locating the double sided pull tape locations.
      • Do not lift on the battery when doing the following step. You will bend it. It is very pliable.
      • Pull the black soft tabs to release the tape's adhesion.
      • Make sure you pull the tabs slowly and continuously away from the case until the adhesive is completely out.
      • Do this to all 4 tabs until the battery is completely free of adhesion to the device's backing.
      댓글 쓰기
    3. Amazon Fire HD 10 Battery Replacement: 7 단계, 이미지 3개 중 1개 Amazon Fire HD 10 Battery Replacement: 7 단계, 이미지 3개 중 2개 Amazon Fire HD 10 Battery Replacement: 7 단계, 이미지 3개 중 3개
      • Make sure all the adhesive is removed before trying to lift the battery from the case.
      • After the battery is totally free of any adhesion, simply lift the battery from the case.
      댓글 쓰기
    4. Amazon Fire HD 10 Battery Replacement: 8 단계, 이미지 3개 중 1개 Amazon Fire HD 10 Battery Replacement: 8 단계, 이미지 3개 중 2개 Amazon Fire HD 10 Battery Replacement: 8 단계, 이미지 3개 중 3개
      • Inspect battery for any leakage.
      • Please follow all U.S. regulations and laws when disposing or recycling the battery.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jaie Hillery
회원 가입일: 10/07/14
1,774 평판
안내서 10개를 작성함
USF Tampa, Team 16-6, Blackwell Winter 2016 USF Tampa, Team 16-6, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S16G6
3 회원들
안내서 52개를 작성함
9가이드 댓글
why is there so much empty space next to the battery?
echow2001 - 답글 공유
Big screen, little processor. The screen dictates the space, that’s why the battery has to be secured with adhesive.
ctgblue - 답글 공유
I’m confused. If it’s a battery replacement issue, why is the battery not listed on the parts list? Is that not necessary once you take the old one out? Where do I get a new battery to replace the one this is teaching me to remove? O.o
tyger.night - 답글 공유
You’ll have to google one. Amazon does not offer one. They want to sell you a new Kindle instead.
I am buying one with the plastic tools (ebay), even if they suck, they should get through this process once.
ctgblue - 답글 공유
How do you know if ita battery or charging port? Mine dont do anything whe. Its
Tech Reviews - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 42
지난 30일: 178
전체 시간: 52,463
