주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon Fire HD 10 Front Facing Camera Replacement
필요한 것
  1. Amazon Fire HD 10 Front Facing Camera Replacement, Screen: 1 단계, 이미지 3개 중 1개 Amazon Fire HD 10 Front Facing Camera Replacement, Screen: 1 단계, 이미지 3개 중 2개 Amazon Fire HD 10 Front Facing Camera Replacement, Screen: 1 단계, 이미지 3개 중 3개
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
    댓글 쓰기
  2. Amazon Fire HD 10 Front Facing Camera Replacement: 2 단계, 이미지 1개 중 1개
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
    댓글 쓰기
  3. Amazon Fire HD 10 Front Facing Camera Replacement: 3 단계, 이미지 2개 중 1개 Amazon Fire HD 10 Front Facing Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
    댓글 쓰기
  4. Amazon Fire HD 10 Front Facing Camera Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the screen and digitizer from the case completely.
    댓글 쓰기
  5. Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: 5 단계, 이미지 3개 중 1개 Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: 5 단계, 이미지 3개 중 2개 Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: 5 단계, 이미지 3개 중 3개
    • Remove the two screws from front facing camera using the T5 Torx Screwdriver.
    • Make sure you place the screws in a safe location nearby.
    댓글 쓰기
  6. Amazon Fire HD 10 Front Facing Camera Replacement: 6 단계, 이미지 2개 중 1개 Amazon Fire HD 10 Front Facing Camera Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the black plastic cover once the screws are removed.
    • Place aside for later reassembly.
    댓글 쓰기
  7. Amazon Fire HD 10 Front Facing Camera Replacement: 7 단계, 이미지 2개 중 1개 Amazon Fire HD 10 Front Facing Camera Replacement: 7 단계, 이미지 2개 중 2개
    • Detach the connector using a plastic opening tool or spudger.
    • The camera is still connected to the motherboard.
    댓글 쓰기
  8. Amazon Fire HD 10 Front Facing Camera Replacement: 8 단계, 이미지 2개 중 1개 Amazon Fire HD 10 Front Facing Camera Replacement: 8 단계, 이미지 2개 중 2개
    • Grip the camera and lift up to detach the ZIF connector from the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jaie Hillery
회원 가입일: 10/07/14
1,774 평판
안내서 10개를 작성함
USF Tampa, Team 16-6, Blackwell Winter 2016 USF Tampa, Team 16-6, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S16G6
3 회원들
안내서 27개를 작성함
1가이드 댓글
Can this camera module be upgraded with a better version?
Jimmy Kee - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 36
전체 시간: 1,601
