소개
This video guide will show you how to solder and fix a broken charging USB port.
필요한 것
동영상 지침
To reassemble your device, follow these instructions in reverse order. Be sure connection pins (in the center of the pad) have enough solder to reattach the the replacement micro-usb.
다른 12명이 해당 안내서를 완성하였습니다.
3가이드 댓글
Can you use usb replacement parts for fire hd 6, 7 and 8.9 for the fire hd 10?
custmadehancraf - 답글 공유
Some English narration instead of the annoying music would be useful. Unsoldering looked rather magical, what was the heat source? Hot air gun under the board? You’re daubing on cleaner and flux, I guess, no idea what’s what. Paste solder?
Alan Corey - 답글 공유
Is there a way to know if it's the battery or the charging port
Tech Reviews - 답글 공유
