주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon Fire HD 7 (4th Generation) Display Replacement
필요한 것
    1. Amazon Fire HD 7 (4th Generation) Display Replacement, Motherboard: 1 단계, 이미지 3개 중 1개 Amazon Fire HD 7 (4th Generation) Display Replacement, Motherboard: 1 단계, 이미지 3개 중 2개 Amazon Fire HD 7 (4th Generation) Display Replacement, Motherboard: 1 단계, 이미지 3개 중 3개
      • Insert the plastic opening tool behind the rear case to free the clips holding the case together.
      • Work your way around the device to free all the clips.
      댓글 쓰기
    2. Amazon Fire HD 7 (4th Generation) Display Replacement: 2 단계, 이미지 1개 중 1개
      • Once all clips have been released, remove the back case to reveal the inside of the device.
      댓글 쓰기
    3. Amazon Fire HD 7 (4th Generation) Display Replacement: 3 단계, 이미지 3개 중 1개 Amazon Fire HD 7 (4th Generation) Display Replacement: 3 단계, 이미지 3개 중 2개 Amazon Fire HD 7 (4th Generation) Display Replacement: 3 단계, 이미지 3개 중 3개
      • Remove the nine silver screws located around the motherboard with the T5 Torx screwdriver.
      댓글 쓰기
    4. Amazon Fire HD 7 (4th Generation) Display Replacement: 4 단계, 이미지 3개 중 1개 Amazon Fire HD 7 (4th Generation) Display Replacement: 4 단계, 이미지 3개 중 2개 Amazon Fire HD 7 (4th Generation) Display Replacement: 4 단계, 이미지 3개 중 3개
      • Remove the six black screws located around the battery and the speaker with the T5 Torx screwdriver.
      • Make your way around the battery and speaker to remove all of them.
      댓글 쓰기
    5. Amazon Fire HD 7 (4th Generation) Display Replacement: 5 단계, 이미지 3개 중 1개 Amazon Fire HD 7 (4th Generation) Display Replacement: 5 단계, 이미지 3개 중 2개 Amazon Fire HD 7 (4th Generation) Display Replacement: 5 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Carefully unplug the three wire connections by placing a plastic spudger under the connections and lifting up.
      • Disconnect the battery and speaker connections by placing the round handle spudger under the wires and lifting up and out.
      • Disconnect the display connections from the motherboard by using the plastic spudger to lift the clamp holding the ribbon cable. Then, using the tweezers, grab the ribbon wire and pull away from the motherboard.
      댓글 쓰기
    6. Amazon Fire HD 7 (4th Generation) Display Replacement: 6 단계, 이미지 2개 중 1개 Amazon Fire HD 7 (4th Generation) Display Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the two screws holding the rear camera in place using the T5 Torx screwdriver.
      • Once freed from the screws, gently lift and remove the rear camera.
      • The camera lens is sensitive. Be careful when removing and handling the rear camera.
      댓글 쓰기
    7. Amazon Fire HD 7 (4th Generation) Display Replacement: 7 단계, 이미지 2개 중 1개 Amazon Fire HD 7 (4th Generation) Display Replacement: 7 단계, 이미지 2개 중 2개
      • Now the motherboard is free to be removed.
      • Lift the motherboard up to remove it as shown in the picture.
      댓글 쓰기
    1. Amazon Fire HD 7 (4th Generation) Display Replacement, Display: 8 단계, 이미지 3개 중 1개 Amazon Fire HD 7 (4th Generation) Display Replacement, Display: 8 단계, 이미지 3개 중 2개 Amazon Fire HD 7 (4th Generation) Display Replacement, Display: 8 단계, 이미지 3개 중 3개
      • Following the bottom edge of the device, remove the (3) T5 hex silver screws with the T5 torx screwdriver.
      댓글 쓰기
    2. Amazon Fire HD 7 (4th Generation) Display Replacement: 9 단계, 이미지 2개 중 1개 Amazon Fire HD 7 (4th Generation) Display Replacement: 9 단계, 이미지 2개 중 2개
      • The motherboard chassis can now be removed to reveal the display screen.
      • Remove the volume button components.
      댓글 쓰기
    3. Amazon Fire HD 7 (4th Generation) Display Replacement: 10 단계, 이미지 3개 중 1개 Amazon Fire HD 7 (4th Generation) Display Replacement: 10 단계, 이미지 3개 중 2개 Amazon Fire HD 7 (4th Generation) Display Replacement: 10 단계, 이미지 3개 중 3개
      • Remove the (4) T5 hex silver screws in the corners of the display screen using the T5 torx screwdriver.
      댓글 쓰기
    4. Amazon Fire HD 7 (4th Generation) Display Replacement: 11 단계, 이미지 3개 중 1개 Amazon Fire HD 7 (4th Generation) Display Replacement: 11 단계, 이미지 3개 중 2개 Amazon Fire HD 7 (4th Generation) Display Replacement: 11 단계, 이미지 3개 중 3개
      • The LCD display screen may now be removed and replaced.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Omir Rosado
회원 가입일: 09/30/16
752 평판
안내서 5개를 작성함
USF Tampa, Team 4-4, Passmore Fall 2016 USF Tampa, Team 4-4, Passmore Fall 2016 회원
USFT-PASSMORE-F16S4G4
4 회원들
안내서 10개를 작성함
1가이드 댓글
finding it very difficult to source a new touch screen for this model.
colin - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 64
전체 시간: 8,025
