주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon Fire Max 11 Charging Port Replacement
필요한 것
    1. Amazon Fire Max 11 Charging Port Replacement, LCD Touch Screen: 1 단계, 이미지 1개 중 1개
      • The heat gun can get very hot and can burn skin. If the device is heated for too long, it can be damaged.
      • Use a heat gun along the edges of the screen to loosen the adhesive.
      • Insert the iFixit opening tool along the seam between the screen and back case and gently pry around the perimeter of the screen.
      댓글 쓰기
    2. Amazon Fire Max 11 Charging Port Replacement: 2 단계, 이미지 2개 중 1개 Amazon Fire Max 11 Charging Port Replacement: 2 단계, 이미지 2개 중 2개
      • Once the screen has been separated from the case, lift it slightly to reveal the display cable connected to the motherboard.
      • Gently push the tip of a spudger under the metal buckle to unclip it, then swing it over the socket.
      • Next, hold the buckle and cable together and gently pull the connector straight out of its socket.
      • To reconnect:
      • Grip the cable and buckle together and insert the connector fully into its socket.
      • Aligning the connector can be tricky. Reposition it as necessary and don't try to force it into the socket, or you may damage both the connector and its socket.
      • Flip the buckle over the socket and use a spudger to press the buckle down until it clicks into place.
      • Remove the screen.
      댓글 쓰기
    1. Amazon Fire Max 11 Charging Port Replacement, Charging Port: 3 단계, 이미지 1개 중 1개
      • Use a Phillips #00 screwdriver to remove the two screws securing the bracket covering the charging port.
      • Remove the black bracket.
      • Use a spudger or a clean fingernail to flip up the locking flap—this is the unlocked position.
      • Use the widest tool possible to avoid damaging the delicate hinge pins.
      • Once the flap is in the unlocked position, use tweezers or your fingers to gently pull the cable out of its socket by the brown tab.
      • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
      댓글 쓰기
    2. Amazon Fire Max 11 Charging Port Replacement: 4 단계, 이미지 1개 중 1개
      • Use a Phillips #00 screwdriver to remove the remaining two screws from the charging port.
      댓글 쓰기
    3. Amazon Fire Max 11 Charging Port Replacement: 5 단계, 이미지 2개 중 1개 Amazon Fire Max 11 Charging Port Replacement: 5 단계, 이미지 2개 중 2개
      • Lift the charging port up slightly at an angle.
      • Disconnect the cable on the back of the board.
      • Slide the charging port out from the tablet.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Anthony Martins
회원 가입일: 03/18/24
522 평판
안내서 4개를 작성함
UMass Dartmouth, Team 1-3, Konn Spring 2024 UMass Dartmouth, Team 1-3, Konn Spring 2024 회원
UMASSD-KONN-S24S1G3
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 44
전체 시간: 1,062
