주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon Fire Phone Battery Replacement
필요한 것
  1. Amazon Fire Phone Battery Replacement, Tape the screen: 1 단계, 이미지 1개 중 1개
    • If the display is damaged, use clear packing tape to contain any glass shards.
    • Make sure the entire surface of the display is covered with tape.
    • Wear safety glasses to protect your eyes.
    댓글 쓰기
  2. Amazon Fire Phone Battery Replacement, Power off, remove SIM card, remove screws: 2 단계, 이미지 3개 중 1개 Amazon Fire Phone Battery Replacement, Power off, remove SIM card, remove screws: 2 단계, 이미지 3개 중 2개 Amazon Fire Phone Battery Replacement, Power off, remove SIM card, remove screws: 2 단계, 이미지 3개 중 3개
    • Power off your phone.
    • Remove the SIM card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
    • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
    댓글 쓰기
  3. Amazon Fire Phone Battery Replacement: 3 단계, 이미지 3개 중 1개 Amazon Fire Phone Battery Replacement: 3 단계, 이미지 3개 중 2개 Amazon Fire Phone Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Press the small suction cup just above the home button.
    • While lifting up on the suction cup insert an opening pick into the crevice between the screen and back casing to pry the screen off carefully.
    • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
    • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone freeing the two halves of the phone.
    댓글 쓰기
  4. Amazon Fire Phone Battery Replacement, Remove Bracket: 4 단계, 이미지 1개 중 1개
    • Using the J000 screwdriver head, remove the three 3mm screws holding the bracket in place.
    • Remove the silver bracket that was held into place by the three screws just removed.
    댓글 쓰기
  5. Amazon Fire Phone Battery Replacement, Disconnect Battery: 5 단계, 이미지 1개 중 1개
    • Disconnect the battery connection cable by using the plastic opening tool and applying light pressure upwards on the cable.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 22명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Lissandra Ilcyn
회원 가입일: 10/05/15
889 평판
안내서 2개를 작성함
Cal Poly, Team 5-7, Maness Fall 2015 Cal Poly, Team 5-7, Maness Fall 2015 회원
CPSU-MANESS-F15S5G7
5 회원들
안내서 15개를 작성함
14가이드 댓글
Tolle Anleitung DANKE!!
Leo Henn - 답글 공유
The replacement went exactly as presented. My stock battery had pull tabs to release the adhesive, making removal very easy. Thanks for a clear step-by-step guide.
John - 답글 공유
How to bay amazone fire fone battry in pakistan
Manzoor Khan - 답글 공유
where can i get fire phone battery in india
Shiva Sai - 답글 공유
where can i get fire phone battery in UAE Abu Dhabi. It's urgent..
Asheesh Barna - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 59
전체 시간: 14,421
