주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon Fire TV Stick Remote Battery Replacement
필요한 것
  1. Amazon Fire TV Stick Remote Battery Replacement, Remote Battery: 1 단계, 이미지 3개 중 1개 Amazon Fire TV Stick Remote Battery Replacement, Remote Battery: 1 단계, 이미지 3개 중 2개 Amazon Fire TV Stick Remote Battery Replacement, Remote Battery: 1 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to press into the seam between the remote and battery cover.
    • With the same tool to help pop the batteries out.
    댓글 쓰기
  2. Amazon Fire TV Stick Remote Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Place two fresh batteries back inside the remote and slide the cover back on.
    • Ensure positive ends of the batteries both point towards the top of the remote.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Andrew Busse
회원 가입일: 07/12/16
939 평판
안내서 2개를 작성함
IUPUI, Team 2-3, Harley SU 2016 IUPUI, Team 2-3, Harley SU 2016 회원
IUPUI-HARLEY-SU16S2G3
4 회원들
안내서 19개를 작성함
35가이드 댓글
do you have to use amazon batteries...my remote doesn't work with duracell
mtimken - 답글 공유
Hey @mtimken ! As far we know, there isnt anything special about Amazon's AAA batteries. Any two *new* AAA batteries should work just fine. Are you certain both of your Duracell batteries are new? Are they rechargeable batteries that need to be charged up fully? Let us know what you find out! Good luck.
Kelsea Weber - 답글 공유
That's my question what type of batteries do I need for my Amazon Fire stick
biba.anderson41 - 답글 공유
The remote takes two AAA batteries. See the answer to the comment above. In the future, go ahead and post your question in the Answers forum : ifixit.com/answers. You may get an answer faster by posting where all of our community members can see your question. I hope this helps. Happy fixing!
Hello having problem with firestick Remote cant get it to work ? i change batteries still not working?
denise carter - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 49
지난 30일: 221
전체 시간: 122,340
