주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon FireTV Stick Motherboard Replacement
필요한 것
  1. Amazon FireTV Stick Motherboard Replacement, Motherboard: 1 단계, 이미지 2개 중 1개 Amazon FireTV Stick Motherboard Replacement, Motherboard: 1 단계, 이미지 2개 중 2개
    • Insert a plastic opening tool into the seam on either side of the device.
    • Side the plastic opening tools along the seam of the stick and pry the top half of the case away from the bottom.
    • Don't force the case apart. If you've successfully unhooked all of the clips, the case will be easy to remove.
    댓글 쓰기
  2. Amazon FireTV Stick Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Amazon FireTV Stick Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the back of the motherboard and slide it out of the case.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 36명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sami Uzzama
회원 가입일: 07/12/16
702 평판
안내서 2개를 작성함
IUPUI, Team 2-3, Harley SU 2016 IUPUI, Team 2-3, Harley SU 2016 회원
IUPUI-HARLEY-SU16S2G3
4 회원들
안내서 19개를 작성함
14가이드 댓글
Where can you purchase a new motherboard for the TV stick?
Brandon Boykin - 답글 공유
Where can you get a new mobo? Mine was defective from day one. Amazon thought it was the remote and replaced the remote. It still didn't work. When I contacted them to state this and get a new stick, they informed me they had refunded my purchase and I would just need to buy a new stick.They said I can through this one away. This was frustrating and being the tinkerer I am I want to get this thing to work now. If there is any info on any connections that I can reinforce that would be great too.
blindzen - 답글 공유
My firestick has no sound and a little headphone icon pops up in the corner of my tv screen…how can i fix it??please heeeellllppp!!
Rzackery - 답글 공유
Your TV sound is off, I think.
[deleted] - 답글 공유
Some issues are caused by the flexing of the Stick (being inserted & removed) around the HDMI connector internally, in addition to the Heat dissipation issues the Fire TV Stick is known for having……. I have just re-soldered the internal cracks around the HDMI connector on my Fire TV Stick & have replaced the Amazon provided USB power adaptor (which is 1.0 ampere) with another adaptor that I have (Which is 1.35 ampere) & the stick is now operating as well if not better than it ever has
Leigh Towers - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 16
지난 7일: 107
지난 30일: 343
전체 시간: 45,368
