주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon Tap Battery Replacement
필요한 것
    1. Amazon Tap Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Use the metal spudger to remove the rubber control panel at the top end of the speaker.
      댓글 쓰기
    2. Amazon Tap Battery Replacement: 2 단계, 이미지 2개 중 1개 Amazon Tap Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Turning the speaker to the bottom end, peel back the Tap's rubber footing.
      • Use a T6 screwdriver to remove the the Tap's base.
      댓글 쓰기
    3. Amazon Tap Battery Replacement: 3 단계, 이미지 2개 중 1개 Amazon Tap Battery Replacement: 3 단계, 이미지 2개 중 2개
      • Time to break through the Tap's exterior. The only way to disassemble the Tap is from the outside.
      • First, remove the Tap's stretchy fabric wrap. Unroll the stretchy fabric from the sticky cowling.
      • After removing the stretchy fabric completely, the adhesive cowling remains.
      댓글 쓰기
    4. Amazon Tap Battery Replacement: 4 단계, 이미지 1개 중 1개
      • Next up: removing the cowling.
      • This step requires many pry tools, and even more patience.
      • The key to remove the cowling is to slide it over the microphone, Bluetooth, and power buttons.
      • Once the cowling is off, only a few screws remain until the interior is reached. Progress!
      댓글 쓰기
    5. Amazon Tap Battery Replacement: 5 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use a pair of tweezers to remove the speaker button while using another pair of tweezers to hold the button steady.
      • Since the button is round, it is best to hold it steady and wiggle it in a slow motion until it comes loose.
      댓글 쓰기
    6. Amazon Tap Battery Replacement: 6 단계, 이미지 2개 중 1개 Amazon Tap Battery Replacement: 6 단계, 이미지 2개 중 2개
      • Once you remove the buttons its safe to pull apart the Amazon Tap.
      • Here you will find a standard 18650 Lithium Ion cell battery.
      • Carefully remove the Lithium Ion Cell Battery and insert a new one.
      댓글 쓰기
결론
To reassemble the Amazon Tap device, follow these instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Hillary Baker
회원 가입일: 04/04/17
337 평판
안내서 1개를 작성함
11가이드 댓글
Wow! Thanks for demystifying this!
ErrOr CReePeR - 답글 공유
Thank you for the guide as it is very helpful! Here is a replacement battery for the Amazon Tap:
Amazon Tap Replacement Battery
It even comes with the necessary tools to complete the repair.
michaelf33707 - 답글 공유
Excellent.
made this very easy for me
cyber_jack99 - 답글 공유
Where does this leave us?? All taken apart and repaired, but with no way to purchase parts to replace the ones ripped apart during removal, nor the skills to put them on looking attractive with near the skills of the Chinese who probably build one of these things every 1.457 minutes at the factory!
Steve Dorff - 답글 공유
Thank you. I was able to replace the battery. Your step by step guide was excellent. Though I could not fix the tip panel correctly I can operate its functions hands free. If show me how to fix top panel I WILL be appreciate
Gopaal goor68 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 121
전체 시간: 14,475
