주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
AmazonBasics B0050BPWBQ On/Off Switch Replacement
필요한 것
    1. AmazonBasics B0050BPWBQ On/Off Switch Replacement, Front and Back Panel Disassembly: 1 단계, 이미지 2개 중 1개 AmazonBasics B0050BPWBQ On/Off Switch Replacement, Front and Back Panel Disassembly: 1 단계, 이미지 2개 중 2개
      • The unit head needs to be switched to the off position and unplugged before any disassembly.
      • When removing screws in the following steps, make sure the unit is resting on a flat surface because pieces will easily come apart.
      • Remove seven 11 mm Phillips #1 screws from the underside of the head unit.
      댓글 쓰기
    2. AmazonBasics B0050BPWBQ On/Off Switch Replacement: 2 단계, 이미지 2개 중 1개 AmazonBasics B0050BPWBQ On/Off Switch Replacement: 2 단계, 이미지 2개 중 2개
      • Upon removal of the next screws, the front panel and the shredding component attached to it will fall apart from the back panel so have the unit resting on a flat surface.
      • Remove two 50 mm Phillips #1 screws from the middle of the underside of the head unit.
      댓글 쓰기
    3. AmazonBasics B0050BPWBQ On/Off Switch Replacement: 3 단계, 이미지 1개 중 1개
      • Lay the back panel away from the front panel on a flat surface.
      • The back panel will be light because it is only the plastic, while the front panel will be heavy with the shredding component attached to it.
      댓글 쓰기
    4. AmazonBasics B0050BPWBQ On/Off Switch Replacement: 4 단계, 이미지 2개 중 1개 AmazonBasics B0050BPWBQ On/Off Switch Replacement: 4 단계, 이미지 2개 중 2개
      • Find the green control board that is located next to the shredding motor.
      • Remove two 11 mm Phillips #1 screws located on opposite sides of the control board.
      • You may need to move wires over to find the screws.
      댓글 쓰기
    1. AmazonBasics B0050BPWBQ On/Off Switch Replacement, On/Off Switch: 5 단계, 이미지 3개 중 1개 AmazonBasics B0050BPWBQ On/Off Switch Replacement, On/Off Switch: 5 단계, 이미지 3개 중 2개 AmazonBasics B0050BPWBQ On/Off Switch Replacement, On/Off Switch: 5 단계, 이미지 3개 중 3개
      • Pull the front panel away from the shredding unit.
      • Locate the black On/Off switch attached to the front panel where the control board was once attached.
      • Squeeze the wings of the On/Off switch from the inside of the front panel to detach it from its slot in the panel.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Natalie Meert
회원 가입일: 02/11/16
741 평판
안내서 4개를 작성함
IUPUI, Team 2-4, Baechle Spring 2016 IUPUI, Team 2-4, Baechle Spring 2016 회원
IUPUI-BAECHLE-S16S2G4
4 회원들
안내서 8개를 작성함
1가이드 댓글
Does anyone know where to buy a replacement switch?
Shawn - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 33
전체 시간: 2,948
