주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
AmazonBasics BTV1 Battery Replacement
필요한 것
    1. AmazonBasics BTV1 Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 AmazonBasics BTV1 Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
      • Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
      댓글 쓰기
    2. AmazonBasics BTV1 Battery Replacement: 2 단계, 이미지 2개 중 1개 AmazonBasics BTV1 Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Using a Phillips #1 screwdriver, remove the four black 10mm screws around each of speakers.
      • Using a Phillps #1 screwdriver, remove the four black 10mm screws securing the inside panel to the case.
      댓글 쓰기
    3. AmazonBasics BTV1 Battery Replacement: 3 단계, 이미지 2개 중 1개 AmazonBasics BTV1 Battery Replacement: 3 단계, 이미지 2개 중 2개
      • Tilt the case downwards until the speakers fall out of their housings.
      • Reach your thumb and forefinger past the speakers and detach the front speaker panel from the unit.
      댓글 쓰기
    4. AmazonBasics BTV1 Battery Replacement: 4 단계, 이미지 2개 중 1개 AmazonBasics BTV1 Battery Replacement: 4 단계, 이미지 2개 중 2개
      • Gently pull each plastic connector from the motherboard.
      • Take a note of which connector goes with each component for easy reassembly.
      • Use a Phillips #1 screwdriver to remove each of the three black 9.6mm screws from the motherboard.
      댓글 쓰기
    5. AmazonBasics BTV1 Battery Replacement: 5 단계, 이미지 2개 중 1개 AmazonBasics BTV1 Battery Replacement: 5 단계, 이미지 2개 중 2개
      • Lift the motherboard off the face plate, exposing the battery.
      • Lift the battery out of its housing.
      • Use caution when using tools around the battery; batteries can be dangerous if punctured.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Chris Shannon
회원 가입일: 02/01/16
1,039 평판
안내서 5개를 작성함
USF Tampa, Team 14-2, Lacy Spring 2016 USF Tampa, Team 14-2, Lacy Spring 2016 회원
USFT-LACY-S16S14G2
3 회원들
안내서 10개를 작성함
8가이드 댓글
donde consigo la bateria?
bnet_d72 - 답글 공유
Nice job, Chris! Thank you.
David Printz - 답글 공유
Hello, anybody know where to get the battery from?
Thank you in advance!
Carlos - 답글 공유
Need information on where to get a replacement battery!
dan - 답글 공유
Whar kind of battery is it? I need to know so that I can order a new one.
Makayla Kersting - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 35
전체 시간: 3,787
