주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Android tablet Nobis NB09 Screen Replacement
필요한 것
    1. Android tablet Nobis NB09 Screen Replacement, Screen: 1 단계, 이미지 3개 중 1개 Android tablet Nobis NB09 Screen Replacement, Screen: 1 단계, 이미지 3개 중 2개 Android tablet Nobis NB09 Screen Replacement, Screen: 1 단계, 이미지 3개 중 3개
      • Remove the two 00 Phillips screws located on the right side of the tablet.
      • Use the plastic opening tools to loosen and then pry the back if the tablet off.
      • When prying off the back of the tablet, be careful around the tablets ports. Too much pressure can cause cracks.
      댓글 쓰기
    2. Android tablet Nobis NB09 Screen Replacement: 2 단계, 이미지 3개 중 1개 Android tablet Nobis NB09 Screen Replacement: 2 단계, 이미지 3개 중 2개 Android tablet Nobis NB09 Screen Replacement: 2 단계, 이미지 3개 중 3개
      • It is recommended that a grounding bracelet be used in order to avoid damage to the device's circuits through ESD (Electro-Static Discharge)
      • Remove the electrical tape covering the motherboard.
      • Remove the four 4.0 mm T4 Torx screws holding the motherboard to the front half of the tablet.
      • Remove any remaining adhesive tape on the exposed area.
      • Disconnect the ribbon cable attachments by lightly pushing up the locking arm (black tab) on each then gently detaching the pin connectors.
      댓글 쓰기
    3. Android tablet Nobis NB09 Screen Replacement: 3 단계, 이미지 3개 중 1개 Android tablet Nobis NB09 Screen Replacement: 3 단계, 이미지 3개 중 2개 Android tablet Nobis NB09 Screen Replacement: 3 단계, 이미지 3개 중 3개
      • Find the notch on the digitzer, located on the left side of the device.
      • Use the Phillips Screwdriver to gently push the notch and lift the digitizer from the screen.
      댓글 쓰기
    4. Android tablet Nobis NB09 Screen Replacement: 4 단계, 이미지 3개 중 1개 Android tablet Nobis NB09 Screen Replacement: 4 단계, 이미지 3개 중 2개 Android tablet Nobis NB09 Screen Replacement: 4 단계, 이미지 3개 중 3개
      • Gently slide the digitizer from its clasps to remove it from the screen.
      • The digitizer should now be removed separately from the screen.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Enea Osmann
회원 가입일: 10/31/14
158 평판
안내서 1개를 작성함
UMass Dartmouth, Team 7-1, Cichon Spring 2015 UMass Dartmouth, Team 7-1, Cichon Spring 2015 회원
UMASSD-CICHON-S15S7G1
4 회원들
안내서 12개를 작성함
2가이드 댓글
The digitizer replacement instructions was great. Thanks
steven warren - 답글 공유
My screen is busted that has the sensor in it do I have to buy a screen or can I use a keyboard?
April sharp - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 25
전체 시간: 1,847
