주요 콘텐츠로 건너뛰기
Anker SoundCore 2 Charging Port Replacement
필요한 것
  1. Anker SoundCore 2 Charging Port Replacement, Front Panel: 1 단계, 이미지 2개 중 1개 Anker SoundCore 2 Charging Port Replacement, Front Panel: 1 단계, 이미지 2개 중 2개
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
  2. Anker SoundCore 2 Charging Port Replacement, Motherboard: 2 단계, 이미지 3개 중 1개 Anker SoundCore 2 Charging Port Replacement, Motherboard: 2 단계, 이미지 3개 중 2개 Anker SoundCore 2 Charging Port Replacement, Motherboard: 2 단계, 이미지 3개 중 3개
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Use your hand to remove the speakers.
  3. Anker SoundCore 2 Charging Port Replacement: 3 단계, 이미지 3개 중 1개 Anker SoundCore 2 Charging Port Replacement: 3 단계, 이미지 3개 중 2개 Anker SoundCore 2 Charging Port Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #0 screwdriver.
    • Flip up the motherboard and disconnect the cord that connects the motherboard and the battery.
  4. Anker SoundCore 2 Charging Port Replacement, Charging Port: 4 단계, 이미지 2개 중 1개 Anker SoundCore 2 Charging Port Replacement, Charging Port: 4 단계, 이미지 2개 중 2개
    • Desolder the charging port from the motherboard and solder a new one on.
    • For help with soldering and desoldering, follow this guide.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Tripp Lersch
회원 가입일: 01/14/21
408 평판
안내서 4개를 작성함
5가이드 댓글
Hello please what's the model of the ESD4 and C34 close to the charging port?
Abel Omeokwe - 답글
Where can i get a replacement charging Port?
A K - 답글
what's the micro usb port part number? I want to replace it but can't find info on it anywhere.
Tomasz Konwalski - 답글
I've made the replacement, but with a spare type c port and...it's not working. Can someone help?
Delyan - 답글
I use Anker OEM style replacement in my repair shop from eBay listing 254057783007
Perfect fit.
https://www.ebay.com/itm/254057783007
Good luck with the project
G.K. - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 93
전체 시간: 4,590
