주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Anker Soundcore Motion 300 Drivers Replacement
필요한 것
  1. Anker Soundcore Motion 300 Drivers Replacement, Speaker Grille: 1 단계, 이미지 2개 중 1개 Anker Soundcore Motion 300 Drivers Replacement, Speaker Grille: 1 단계, 이미지 2개 중 2개
    • Insert an opening tool into a seam between the grille and chassis.
    • Gently pry the grille up to begin disengaging the retaining clip.
    • Once a corner starts to lift, slowly slide the tool along the edge to loosen more of the grille.
    댓글 쓰기
  2. Anker Soundcore Motion 300 Drivers Replacement: 2 단계, 이미지 2개 중 1개 Anker Soundcore Motion 300 Drivers Replacement: 2 단계, 이미지 2개 중 2개
    • Keep working around the edges until all the clips are loose.
    • You may hear soft clicking sounds as the clips come undone.
    댓글 쓰기
  3. Anker Soundcore Motion 300 Drivers Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully remove the grille from the speaker.
    댓글 쓰기
  4. Anker Soundcore Motion 300 Drivers Replacement, Drivers: 4 단계, 이미지 3개 중 1개 Anker Soundcore Motion 300 Drivers Replacement, Drivers: 4 단계, 이미지 3개 중 2개 Anker Soundcore Motion 300 Drivers Replacement, Drivers: 4 단계, 이미지 3개 중 3개
    • Use a Phillips #0 screwdriver to remove all eight 11.5 mm screws that secure the driver housing.
    댓글 쓰기
  5. Anker Soundcore Motion 300 Drivers Replacement: 5 단계, 이미지 3개 중 1개 Anker Soundcore Motion 300 Drivers Replacement: 5 단계, 이미지 3개 중 2개 Anker Soundcore Motion 300 Drivers Replacement: 5 단계, 이미지 3개 중 3개
    • Use an opening tool to pry up the speaker housing.
    • Set the speaker housing beside the speaker, with care not to strain the cables connected to the drivers.
    • The speaker housing may be very difficult to remove due to adhesive. If necessary, use a hairdryer to lightly heat the perimeter of the housing to loosen the adhesive.
    댓글 쓰기
  6. Anker Soundcore Motion 300 Drivers Replacement: 6 단계, 이미지 3개 중 1개 Anker Soundcore Motion 300 Drivers Replacement: 6 단계, 이미지 3개 중 2개 Anker Soundcore Motion 300 Drivers Replacement: 6 단계, 이미지 3개 중 3개
    • With a Phillips #0 screwdriver, remove the four 7.5 mm screws that secure the driver.
    • Repeat the previous bullet for the other driver.
    • Gently lift off the drivers; the speakers may be slightly glued or stuck to the plastic plate so try not pull on the wiring attaching the components.
    • Disconnect each of the the two driver connectors from the motherboard.
    • There may be a small piece of sealant that must be removed before the connectors can be removed.
    • Remove the drivers.
    댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Holly Hoffman
회원 가입일: 02/17/25
487 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 19
지난 30일: 75
전체 시간: 595
