주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Anker Soundcore Motion Boom Plus Subwoofer Replacement
필요한 것
    1. Anker Soundcore Motion Boom Plus Subwoofer Replacement, Case: 1 단계, 이미지 3개 중 1개 Anker Soundcore Motion Boom Plus Subwoofer Replacement, Case: 1 단계, 이미지 3개 중 2개 Anker Soundcore Motion Boom Plus Subwoofer Replacement, Case: 1 단계, 이미지 3개 중 3개
      • Insert an opening tool into the seam between the speaker grille and the chassis.
      • Pry the tool around the top, bottom, and sides until the grille fully releases.
      • Apply gentle pressure to avoid damaging the grille.
      • Remove the grille.
      댓글 쓰기
    2. Anker Soundcore Motion Boom Plus Subwoofer Replacement: 2 단계, 이미지 2개 중 1개 Anker Soundcore Motion Boom Plus Subwoofer Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the two passive radiators on either side of the device.
      • Avoid pulling too hard or with too much force to prevent breaking the passive radiators.
      댓글 쓰기
    3. Anker Soundcore Motion Boom Plus Subwoofer Replacement: 3 단계, 이미지 2개 중 1개 Anker Soundcore Motion Boom Plus Subwoofer Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the sixteen 14 mm Phillips screws, eight on each end of the speaker.
      댓글 쓰기
    4. Anker Soundcore Motion Boom Plus Subwoofer Replacement: 4 단계, 이미지 3개 중 1개 Anker Soundcore Motion Boom Plus Subwoofer Replacement: 4 단계, 이미지 3개 중 2개 Anker Soundcore Motion Boom Plus Subwoofer Replacement: 4 단계, 이미지 3개 중 3개
      • Gently remove the handle from the device by clicking off the handles from the sides and then pulling it off.
      댓글 쓰기
    5. Anker Soundcore Motion Boom Plus Subwoofer Replacement: 5 단계, 이미지 2개 중 1개 Anker Soundcore Motion Boom Plus Subwoofer Replacement: 5 단계, 이미지 2개 중 2개
      • Flip the speaker onto its side and use a spudger to remove the two rubber feet on the bottom of the device.
      댓글 쓰기
    6. Anker Soundcore Motion Boom Plus Subwoofer Replacement: 6 단계, 이미지 2개 중 1개 Anker Soundcore Motion Boom Plus Subwoofer Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the eleven 13 mm Philips screws that secure the driver housing.
      댓글 쓰기
    7. Anker Soundcore Motion Boom Plus Subwoofer Replacement: 7 단계, 이미지 2개 중 1개 Anker Soundcore Motion Boom Plus Subwoofer Replacement: 7 단계, 이미지 2개 중 2개
      • Remove the two 14 mm Phillips screws located on each side of the handle, near the clip points.
      댓글 쓰기
    8. Anker Soundcore Motion Boom Plus Subwoofer Replacement: 8 단계, 이미지 2개 중 1개 Anker Soundcore Motion Boom Plus Subwoofer Replacement: 8 단계, 이미지 2개 중 2개
      • Remove the four 14 mm Philips screws on the top of the device.
      댓글 쓰기
    9. Anker Soundcore Motion Boom Plus Subwoofer Replacement: 9 단계, 이미지 1개 중 1개
      • Insert a spudger into the seam on top of the device.
      • Gently pry the casing open.
      댓글 쓰기
    10. Anker Soundcore Motion Boom Plus Subwoofer Replacement: 10 단계, 이미지 3개 중 1개 Anker Soundcore Motion Boom Plus Subwoofer Replacement: 10 단계, 이미지 3개 중 2개 Anker Soundcore Motion Boom Plus Subwoofer Replacement: 10 단계, 이미지 3개 중 3개
      • Disconnect each of the three cables by gently pulling the connectors out of their sockets.
      • Do not pull with force. The ribbon cables are fragile and easily break.
      댓글 쓰기
    1. Anker Soundcore Motion Boom Plus Subwoofer Replacement, Subwoofer: 11 단계, 이미지 3개 중 1개 Anker Soundcore Motion Boom Plus Subwoofer Replacement, Subwoofer: 11 단계, 이미지 3개 중 2개 Anker Soundcore Motion Boom Plus Subwoofer Replacement, Subwoofer: 11 단계, 이미지 3개 중 3개
      • Remove the four 11 mm Phillips screws securing the right subwoofer.
      • Gently pull the subwoofer out of the device.
      댓글 쓰기
    2. Anker Soundcore Motion Boom Plus Subwoofer Replacement: 12 단계, 이미지 1개 중 1개
      • Detach the cables connected to the subwoofer.
      • Do not pull with force, as the cables are fragile and easily break.
      • Remove the right subwoofer.
      • Repeat the previous two steps for the left subwoofer.
      댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Hayley
회원 가입일: 03/26/25
988 평판
안내서 6개를 작성함
UMass Dartmouth, Team 3-7, Botvin Spring 2025 UMass Dartmouth, Team 3-7, Botvin Spring 2025 회원
UMASSD-BOTVIN-S25S3G7
2 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 33
전체 시간: 336
