주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Anker Soundcore Motion Boom Plus Tweeter Replacement
필요한 것
  1. Anker Soundcore Motion Boom Plus Tweeter Replacement, Case: 1 단계, 이미지 3개 중 1개 Anker Soundcore Motion Boom Plus Tweeter Replacement, Case: 1 단계, 이미지 3개 중 2개 Anker Soundcore Motion Boom Plus Tweeter Replacement, Case: 1 단계, 이미지 3개 중 3개
    • Insert an opening tool into the seam between the speaker grille and the chassis.
    • Pry the tool around the top, bottom, and sides until the grille fully releases.
    • Apply gentle pressure to avoid damaging the grille.
    • Remove the grille.
    댓글 쓰기
  2. Anker Soundcore Motion Boom Plus Tweeter Replacement: 2 단계, 이미지 2개 중 1개 Anker Soundcore Motion Boom Plus Tweeter Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the two passive radiators on either side of the device.
    • Avoid pulling too hard or with too much force to prevent breaking the passive radiators.
    댓글 쓰기
  3. Anker Soundcore Motion Boom Plus Tweeter Replacement: 3 단계, 이미지 2개 중 1개 Anker Soundcore Motion Boom Plus Tweeter Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the sixteen 14 mm Phillips screws, eight on each end of the speaker.
    댓글 쓰기
  4. Anker Soundcore Motion Boom Plus Tweeter Replacement: 4 단계, 이미지 3개 중 1개 Anker Soundcore Motion Boom Plus Tweeter Replacement: 4 단계, 이미지 3개 중 2개 Anker Soundcore Motion Boom Plus Tweeter Replacement: 4 단계, 이미지 3개 중 3개
    • Gently remove the handle from the device by clicking off the handles from the sides and then pulling it off.
    댓글 쓰기
  5. Anker Soundcore Motion Boom Plus Tweeter Replacement: 5 단계, 이미지 2개 중 1개 Anker Soundcore Motion Boom Plus Tweeter Replacement: 5 단계, 이미지 2개 중 2개
    • Flip the speaker onto its side and use a spudger to remove the two rubber feet on the bottom of the device.
    댓글 쓰기
  6. Anker Soundcore Motion Boom Plus Tweeter Replacement: 6 단계, 이미지 2개 중 1개 Anker Soundcore Motion Boom Plus Tweeter Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the eleven 13 mm Philips screws that secure the driver housing.
    댓글 쓰기
  7. Anker Soundcore Motion Boom Plus Tweeter Replacement: 7 단계, 이미지 2개 중 1개 Anker Soundcore Motion Boom Plus Tweeter Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the two 14 mm Phillips screws located on each side of the handle, near the clip points.
    댓글 쓰기
  8. Anker Soundcore Motion Boom Plus Tweeter Replacement: 8 단계, 이미지 2개 중 1개 Anker Soundcore Motion Boom Plus Tweeter Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the four 14 mm Philips screws on the top of the device.
    댓글 쓰기
  9. Anker Soundcore Motion Boom Plus Tweeter Replacement: 9 단계, 이미지 1개 중 1개
    • Insert a spudger into the seam on top of the device.
    • Gently pry the casing open.
    댓글 쓰기
  10. Anker Soundcore Motion Boom Plus Tweeter Replacement: 10 단계, 이미지 3개 중 1개 Anker Soundcore Motion Boom Plus Tweeter Replacement: 10 단계, 이미지 3개 중 2개 Anker Soundcore Motion Boom Plus Tweeter Replacement: 10 단계, 이미지 3개 중 3개
    • Disconnect each of the three cables by gently pulling the connectors out of their sockets.
    • Do not pull with force. The ribbon cables are fragile and easily break.
    댓글 쓰기
  11. Anker Soundcore Motion Boom Plus Tweeter Replacement, Tweeter: 11 단계, 이미지 2개 중 1개 Anker Soundcore Motion Boom Plus Tweeter Replacement, Tweeter: 11 단계, 이미지 2개 중 2개
    • Disconnect the ribbon cables attached to the tweeters by pulling them off gently.
    • Avoid pulling too hard on the ribbon cables as they are fragile and easily break.
    댓글 쓰기
  12. Anker Soundcore Motion Boom Plus Tweeter Replacement: 12 단계, 이미지 1개 중 1개
    • Push the tweeters from the front side, and the tweeters should pop out. Remove and replace the tweeters with new ones.
    댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Hayley
회원 가입일: 03/26/25
988 평판
안내서 6개를 작성함
UMass Dartmouth, Team 3-7, Botvin Spring 2025 UMass Dartmouth, Team 3-7, Botvin Spring 2025 회원
UMASSD-BOTVIN-S25S3G7
2 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 32
전체 시간: 298
