주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Anker Soundcore Select Pro A 3126 Button Panel Replacement
필요한 것
    1. Anker Soundcore Select Pro A 3126 Button Panel Replacement, Button Panel: 1 단계, 이미지 2개 중 1개 Anker Soundcore Select Pro A 3126 Button Panel Replacement, Button Panel: 1 단계, 이미지 2개 중 2개
      • Use a spudger to remove each side speaker cover by inserting it in the crevice and using moderate force to pry them off.
      댓글 쓰기
    2. Anker Soundcore Select Pro A 3126 Button Panel Replacement: 2 단계, 이미지 2개 중 1개 Anker Soundcore Select Pro A 3126 Button Panel Replacement: 2 단계, 이미지 2개 중 2개
      • Insert a spudger into the space between the grille and speaker frame to pry the mesh grille covering the front speakers.
      댓글 쓰기
    3. Anker Soundcore Select Pro A 3126 Button Panel Replacement: 3 단계, 이미지 1개 중 1개
      • Use a Phillips #1 screwdriver to remove the eight 12.7 mm screws securing the front cover.
      댓글 쓰기
    4. Anker Soundcore Select Pro A 3126 Button Panel Replacement: 4 단계, 이미지 1개 중 1개
      • Using a Phillips #1 screwdriver, remove the eight 8.75 mm screws around the corners of each speaker.
      댓글 쓰기
    5. Anker Soundcore Select Pro A 3126 Button Panel Replacement: 5 단계, 이미지 1개 중 1개
      • Flip the speaker so you have access to the bottom of the device.
      • Use a spudger to remove both rubber pads that protect the bottom of the device.
      댓글 쓰기
    6. Anker Soundcore Select Pro A 3126 Button Panel Replacement: 6 단계, 이미지 1개 중 1개
      • Using a spudger remove the rubber pad on the top handle to expose 3 screws underneath.
      • Using a Phillips #1 screwdriver, remove the three 6.75 mm screws.
      댓글 쓰기
    7. Anker Soundcore Select Pro A 3126 Button Panel Replacement: 7 단계, 이미지 3개 중 1개 Anker Soundcore Select Pro A 3126 Button Panel Replacement: 7 단계, 이미지 3개 중 2개 Anker Soundcore Select Pro A 3126 Button Panel Replacement: 7 단계, 이미지 3개 중 3개
      • Using a spudger, pry open the front half of the speaker.
      • The front and back halves of the speaker are connected by several cables. Open the speaker slowly and avoid pulling on the cables, as they can be damaged easily.
      댓글 쓰기
    8. Anker Soundcore Select Pro A 3126 Button Panel Replacement: 8 단계, 이미지 1개 중 1개
      • Use a Phillips #1 screwdriver to remove the eight 6.5 mm screws securing the button board.
      댓글 쓰기
    9. Anker Soundcore Select Pro A 3126 Button Panel Replacement: 9 단계, 이미지 2개 중 1개 Anker Soundcore Select Pro A 3126 Button Panel Replacement: 9 단계, 이미지 2개 중 2개
      • Use the tip of the spudger to push the black plastic locking tab away from the socket.
      • Pull the ribbon cable straight out of the socket.
      • Remove the old button board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Matthew Garza
회원 가입일: 02/24/26
387 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 45
전체 시간: 100
