주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apex Tablet 7 Camera Replacement
필요한 것
    1. Apex Tablet 7 Camera Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
      • Unscrew the two 2.70 mm Phillips #00 screws on the side of the tablet that has the buttons and the headphone jack (bottom side when holding upright).
      댓글 쓰기
    2. Apex Tablet 7 Camera Replacement: 2 단계, 이미지 2개 중 1개 Apex Tablet 7 Camera Replacement: 2 단계, 이미지 2개 중 2개
      • CAUTION: When removing the back panel of the tablet, take caution around the speaker. This is located in the lower right corner when looking at the back of the tablet. There are two wires inside connecting the tablet back panel to the device itself and this connection may be severed if the back is pulled off without care.
      • This connection is shown in red on the pictures.
      댓글 쓰기
    3. Apex Tablet 7 Camera Replacement: 3 단계, 이미지 2개 중 1개 Apex Tablet 7 Camera Replacement: 3 단계, 이미지 2개 중 2개
      • Slide a plastic opening tool in between the edge of the back panel and the the top edge of the device.
      • Run the plastic opening tool along the sides of the tablet while keeping it in the crack between the tablet and the back panel to create an opening.
      댓글 쓰기
    4. Apex Tablet 7 Camera Replacement: 4 단계, 이미지 1개 중 1개
      • Apply pressure using your hand to pop the back panel off slowly, taking extra care around the speaker connection.
      댓글 쓰기
    5. Apex Tablet 7 Camera Replacement: 5 단계, 이미지 1개 중 1개
      • The back panel should now be disconnected from the device. This provides access to the components of the device for repairing and replacing parts of the tablet.
      댓글 쓰기
    1. Apex Tablet 7 Camera Replacement, Camera: 6 단계, 이미지 2개 중 1개 Apex Tablet 7 Camera Replacement, Camera: 6 단계, 이미지 2개 중 2개
      • Gently remove the black tape covering the camera and circuit board. The tape will be connected to a foamy block on the back of the actual camera component.
      댓글 쓰기
    2. Apex Tablet 7 Camera Replacement: 7 단계, 이미지 1개 중 1개
      • Flip the black latch over the gold cable to the upright position in order to release the cable.
      댓글 쓰기
    3. Apex Tablet 7 Camera Replacement: 8 단계, 이미지 1개 중 1개
      • Carefully remove the cable from the circuit by pulling it straight out.
      댓글 쓰기
    4. Apex Tablet 7 Camera Replacement: 9 단계, 이미지 1개 중 1개
      • Pull out the camera. There should not be any more connections holding it in place.
      • Reconnect the replacement camera.
      댓글 쓰기
결론
To place the new part and reassemble your device, follow these instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Steven Gutzwiller
회원 가입일: 03/20/15
480 평판
안내서 3개를 작성함
Baylor, Team 2-2, Grigsby Spring 2015 Baylor, Team 2-2, Grigsby Spring 2015 회원
BU-GRIGSBY-S15S2G2
4 회원들
안내서 30개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 27
전체 시간: 728
