주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple Magic Keyboard Keys Repair
필요한 것
      • Remove the batteries.
      • Remove the plastic cover on the bottom. (On older models, this cover is not centered.)
      • Remove the small screw.
      댓글 쓰기
      • Use a flat blunt tool to loosen the ribbon cable clamp. To do this, pull the front part away from the rear part.
      • Pull out the ribbon cable.
      댓글 쓰기
      • Put the batteries back in (without screwing the cover on).
      • Push in the batteries to release the circuit board assembly.
      • Carefully pull out the circuit board assembly. Pay attention to the ribbon cable.
      댓글 쓰기
      • Soak the keyboard in alcohol (methylated spirits). It should be completely covered. Use an airtight container.
      • Keep moving the container to get the liquid everywhere.
      • Wait 24 hours
      댓글 쓰기
      • Take the keyboard out of the liquid and shake it out well.
      • CAUTION!! This step is not absolutely necessary!! Opening the keyboard further is only necessary if you want to gain access to the circuit paths.
      • The plastic cover on the back can now be easily detached. To do this, use a flat blunt tool to go into the gap and pry off the plastic cover. The alcohol has softened the glue.
      • Let the keyboard dry well. To speed up the process, you can put it into the sun.
      댓글 쓰기
      • Put the parts back together in reverse order. When installing the circuit board unit, make sure that you pull the ribbon cable to the side.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
2다른 기여자 명과 함께
Sebastian Reindl
회원 가입일: 05/02/20
268 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 38
지난 30일: 191
전체 시간: 6,414
