주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple PowerBook G3 400 RAM Replacement
필요한 것
    1. Apple PowerBook G3 400 RAM Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
      • Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
      • To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
      댓글 쓰기
    2. Apple PowerBook G3 400 RAM Replacement: 2 단계, 이미지 1개 중 1개
      • Pull the keyboard ribbon vertically from the logic board to release connection.
      • The connector may be tight and difficult to remove. If stuck try rocking the connector back and forth while pulling up until it releases. This same process can be used for many of the connectors on this device.
      • Remove battery and CD/DVD drives before proceeding any further.
      댓글 쓰기
    3. Apple PowerBook G3 400 RAM Replacement: 3 단계, 이미지 1개 중 1개
      • Your computer should look approximately like this.
      댓글 쓰기
    1. Apple PowerBook G3 400 RAM Replacement, RAM: 4 단계, 이미지 1개 중 1개
      • Remove the two silver Phillips #1 screws that attach the heat shield to the metal framework.
      • Lift the heat shield up and toward you.
      댓글 쓰기
    2. Apple PowerBook G3 400 RAM Replacement: 5 단계, 이미지 1개 중 1개
      • Pull the PRAM battery cable vertically upward to disconnect it.
      • Remove the battery by pulling up and to the left.
      댓글 쓰기
    3. Apple PowerBook G3 400 RAM Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the two T8 Torx screws that attach the heat sink to the processor.
      • Remove the long silver Phillips #1 screw from the heat sink.
      댓글 쓰기
    4. Apple PowerBook G3 400 RAM Replacement: 7 단계, 이미지 1개 중 1개
      • Lift up the heat sink unit from the left side and remove.
      댓글 쓰기
    5. Apple PowerBook G3 400 RAM Replacement: 8 단계, 이미지 1개 중 1개
      • Lift the processor on the right side and pull directly up.
      • The RAM chips should be in the slots on the processor.
      댓글 쓰기
    6. Apple PowerBook G3 400 RAM Replacement: 9 단계, 이미지 1개 중 1개
      • After removing the RAM, your laptop should now look like this.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Ian
회원 가입일: 04/18/11
57 평판
안내서 1개를 작성함
Cal Poly, Team 4-2, Regan Spring 2011 Cal Poly, Team 4-2, Regan Spring 2011 회원
CPSU-REGAN-S11S4G2
4 회원들
안내서 42개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 35
전체 시간: 2,539
