주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple Powerbook 5300 Memory Replacement
필요한 것
    1. Apple Powerbook 5300 Memory Replacement, Battery: 1 단계, 이미지 2개 중 1개 Apple Powerbook 5300 Memory Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • To begin this repair process first position the Powerbook towards you with the monitor closed, also make sure the laptop is away from anything that can cause a fire, self harm, etc.
      • Press the battery removal latch located on the right side of the front panel.
      • Gently slide the battery out. Make sure you place the battery in a safe place where it can also be easily accesible
      • ALSO NOTE: The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
      댓글 쓰기
    1. Apple Powerbook 5300 Memory Replacement, Keyboard: 2 단계, 이미지 1개 중 1개
      • For the next step you are to grab the TR8 Torx Security Screwdriver
      • Once you have the screwdriver turn the laptop over and look for three T8 torx screws that should be located near the bottom panel of the device.
      • Once located, begin unscrewing and place screws in a comfortable space where they are easily accesible
      댓글 쓰기
    2. Apple Powerbook 5300 Memory Replacement: 3 단계, 이미지 1개 중 1개
      • Once the screws are off carefully turn the laptop over, make sure the monitor of the device is facing you
      • With the monitor facing towards you, gently pull up on the keyboard panel from the bottom.
      • With the keyboard turned over as pictured, carefully remove its ribbon cable from the connection port on the logic board. Use the spudger tool to lift the white plastic retainer about 1/16" to release the cable.
      댓글 쓰기
    1. Apple Powerbook 5300 Memory Replacement, Memory: 4 단계, 이미지 1개 중 1개
      • Pull up on the large green memory chip on the left side of the laptop. It will simply lift out.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Scott
회원 가입일: 04/26/11
155 평판
안내서 5개를 작성함
Cal Poly, Team 25-30, Garner Spring 2011 Cal Poly, Team 25-30, Garner Spring 2011 회원
CPSU-GARNER-S11S25G30
4 회원들
안내서 42개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 32
전체 시간: 2,904
