주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple Studio Display M2454 Main Computer Cable Replacement
필요한 것
    1. Apple Studio Display M2454 Main Computer Cable Replacement, Main Computer Cable: 1 단계, 이미지 1개 중 1개
      • First, the back panel needs to be removed to access the cable connectors.
      • Locate the three 2mm hex screws located on the top of the stand and remove them.
      • Now locate and remove the four 2mm hex screws on the corners of the back panel.
      • Now remove the back panels while pulling the cable through them without damaging either part.
      댓글 쓰기
    2. Apple Studio Display M2454 Main Computer Cable Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the metal back plate by using the #2 philips head screwdriver and removing the top screw.
      • Now remove the two other philips screws located below the cable with the philips head screwdriver.
      • With all the screws removed, push the metal plate towards the bottom of the monitor to release the clips holding it to the monitor.
      • Pull the metal plate away.
      댓글 쓰기
    3. Apple Studio Display M2454 Main Computer Cable Replacement: 3 단계, 이미지 1개 중 1개
      • Locate and remove the four #2 phillips screws located on the corners of the stand bracket, using the phillips head screwdriver.
      • Pull bracket away from monitor.
      댓글 쓰기
    4. Apple Studio Display M2454 Main Computer Cable Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the cable hold-down with #2 phillips head screwdriver.
      댓글 쓰기
    5. Apple Studio Display M2454 Main Computer Cable Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the screw at the bottom of the plastic bracket, using #2 phillips head screwdriver.
      • Pull the plastic bracket free.
      • Note the plastic pegs lining the bracket up with the monitor.
      댓글 쓰기
    6. Apple Studio Display M2454 Main Computer Cable Replacement: 6 단계, 이미지 1개 중 1개
      • Remove tape holding down the white connector to the LCD main board.
      댓글 쓰기
    7. Apple Studio Display M2454 Main Computer Cable Replacement: 7 단계, 이미지 1개 중 1개
      • With tape removed, the connections on the LCD main board can be disconnected.
      • First, remove the single hold-down using the philips head screwdriver.
      • Now locate the three connections the main cable makes with the monitor. Two are on the LCD Main Board and one other to the side.
      • Disconnect the white connector to the LCD main board by gently lifting tab with small pry tool and pulling out.
      • The tabs can easily break off, be extra careful
      • Disconnect the black connector to the LCD main board by pressing the tab and pulling out.
      댓글 쓰기
    8. Apple Studio Display M2454 Main Computer Cable Replacement: 8 단계, 이미지 1개 중 1개
      • Now remove the connection not on the LCD Main Board by pulling back the tape holding the wires down first.
      • Remove the connector by hand.
      댓글 쓰기
    9. Apple Studio Display M2454 Main Computer Cable Replacement: 9 단계, 이미지 1개 중 1개
      • Finally, the main cable can be replaced by pulling the old cable away and repeating the previous steps in reverse with a new, working main cable.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Dylan Perry
회원 가입일: 01/20/10
177 평판
안내서 5개를 작성함
Cal Poly, Team 13-27, Maness Winter 2010 Cal Poly, Team 13-27, Maness Winter 2010 회원
CPSU-MANESS-W10S13G27
4 회원들
안내서 19개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 49
전체 시간: 6,479
