주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple TV 1st Generation Fan Replacement
필요한 것
    1. Apple TV 1st Generation Fan Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
      • Flip the Apple TV over so that the bottom of the unit is facing up.
      • You need to remove the rubber base to get access to the screws.
      • Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
      • The rubber base will be hot after heating, take extreme caution while proceeding to avoid personal injury.
      • While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
      • The rubber base can tear if the adhesive hasn't been softened enough.
      • Repeat the procedure described above until the rubber base has been completely removed.
      댓글 쓰기
    2. Apple TV 1st Generation Fan Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the four T10 Torx screws that secure the lower case to the upper case.
      댓글 쓰기
    3. Apple TV 1st Generation Fan Replacement: 3 단계, 이미지 1개 중 1개
      • Carefully lift the lower case from the upper case enough to allow access to the internals of the Apple TV.
      • Be aware that the hard drive is physically attached to the lower case and that a ribbon cable runs from the drive to the logic board in the upper case.
      댓글 쓰기
    4. Apple TV 1st Generation Fan Replacement: 4 단계, 이미지 2개 중 1개 Apple TV 1st Generation Fan Replacement: 4 단계, 이미지 2개 중 2개
      • Carefully pull the hard drive data cable straight up from its socket on the logic board.
      • During reassembly, make sure the hard drive data cable is firmly seated in its socket on the logic board; otherwise, during boot-up you will see a flashing question mark "?".
      댓글 쓰기
    1. Apple TV 1st Generation Fan Replacement, Fan: 5 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • The fan is held in place by three rubber posts.
      • Using a pair of tweezers, squeeze the top of each post and push the post down into the hole. Repeat for all three posts.
      • During reinstallation, it helps to lubricate the rubber posts. Try weaving a string through the holes in the posts to pull them up through the mounting points.
      • Do not excessively pull on the posts, as they may rip.
      댓글 쓰기
    2. Apple TV 1st Generation Fan Replacement: 6 단계, 이미지 1개 중 1개
      • Using a pair of tweezers, pull the fan connector straight up from its socket on the logic board.
      • Lift and remove the fan out of the upper case.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
ropel
회원 가입일: 11/11/09
119 평판
안내서 2개를 작성함
Cal Poly, Team 18-5, Maness Fall 2009 Cal Poly, Team 18-5, Maness Fall 2009 회원
CPSU-MANESS-F09S18G5
5 회원들
안내서 25개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 55
전체 시간: 12,600
