주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple TV 3rd Generation Power Supply Replacement
필요한 것
    1. Apple TV 3rd Generation Power Supply Replacement, Snap-on Base: 1 단계, 이미지 1개 중 1개
      • As the device base is firmly clipped, insert two metal spudgers to gently release the first clips.
      댓글 쓰기
    2. Apple TV 3rd Generation Power Supply Replacement: 2 단계, 이미지 1개 중 1개
      • Continue releasing the last plastic clips with your hands taking care not to break any of the plastic elements attached to the base.
      댓글 쓰기
    1. Apple TV 3rd Generation Power Supply Replacement, Logic Board: 3 단계, 이미지 1개 중 1개
      • Use a philips screwdriver to remove the 5 screws securing the metal heat sink. On Rev A (A1469) you need a T7 srewdriver
      댓글 쓰기
    2. Apple TV 3rd Generation Power Supply Replacement: 4 단계, 이미지 2개 중 1개 Apple TV 3rd Generation Power Supply Replacement: 4 단계, 이미지 2개 중 2개
      • Disconnect the power supply connector from the logic board with a spudger.
      댓글 쓰기
    1. Apple TV 3rd Generation Power Supply Replacement, Power Supply: 5 단계, 이미지 2개 중 1개 Apple TV 3rd Generation Power Supply Replacement, Power Supply: 5 단계, 이미지 2개 중 2개
      • Before you remove completely the power supply, unscrew the T6 screws on each side of the socket.
      • You may now be able to remove the power supply with a spudger.
      • Do not pull the wires to remove the power supply. The connector is fragile.
      • The rating of the power supply is 3.4V at 1.75A, which is identical to the 2nd Gen Apple TV's 5.95 watts.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 14명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Vincent Monteil
회원 가입일: 07/06/13
7,031 평판
안내서 19개를 작성함
11가이드 댓글
you forgot to add the power supply is held by 2 tiny torx screw
morpheuse - 답글 공유
Successfully sourced a new power supply for our 3rd generation after the last one was destroyed ironically by Apple juice. Sourced from China and replaced- presto!! It's working- all for $14.95
rcbakes30 - 답글 공유
Where? I need on badly! Can you send me / Post here a link?
jakesterage - 답글 공유
please, and where could be find the part, the power supply for AppleTV 3rd generation?
foxy72 - 답글 공유
Hi, i have a 3rd gen Apple TV and I have problems with it, it doesn't turn on I don't now if it's the power supply or it is &&^&@@ up how can I figure out if it is the power supply and in that case where can I found one
ilichcorcegatreep - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 68
전체 시간: 21,445
