주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple TV 4K Power Connector Replacement
필요한 것
  1. Apple TV 4K Power Connector Replacement, Logic Board: 1 단계, 이미지 1개 중 1개
    • Use a spudger to pry the bottom panel off from the body. It is held on with clips on the inside, so you will need to make sure those are undone while opening.
    • The panel is held onto the device tightly, so you may need to be a bit forceful to remove it.
    댓글 쓰기
  2. Apple TV 4K Power Connector Replacement: 2 단계, 이미지 2개 중 1개 Apple TV 4K Power Connector Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the following screws using a T6 Torx screwdriver holding the heat sink assembly in.
    • Four 10 mm screws
    • Lift and remove the heat sink assembly from the device.
    댓글 쓰기
  3. Apple TV 4K Power Connector Replacement: 3 단계, 이미지 2개 중 1개 Apple TV 4K Power Connector Replacement: 3 단계, 이미지 2개 중 2개
    • Use plastic spudger to pull up on all three antenna connectors to remove them.
    • Remove rubber piece from front side of device.
    댓글 쓰기
  4. Apple TV 4K Power Connector Replacement: 4 단계, 이미지 1개 중 1개
    • Unscrew the following screws holding the logic board in place using the T7 Torx:
    • Two black 3 mm screws
    • Two silver 4 mm screws
    댓글 쓰기
  5. Apple TV 4K Power Connector Replacement: 5 단계, 이미지 3개 중 1개 Apple TV 4K Power Connector Replacement: 5 단계, 이미지 3개 중 2개 Apple TV 4K Power Connector Replacement: 5 단계, 이미지 3개 중 3개
    • Use a spudger to pry up logic board. Try lifting it up from the front side.
    • Remove logic board and set aside.
    댓글 쓰기
  6. Apple TV 4K Power Connector Replacement, Power Connector: 6 단계, 이미지 3개 중 1개 Apple TV 4K Power Connector Replacement, Power Connector: 6 단계, 이미지 3개 중 2개 Apple TV 4K Power Connector Replacement, Power Connector: 6 단계, 이미지 3개 중 3개
    • Use a T7 Torx to remove the screws:
    • Five 5mm screws
    • Carefully flip the device upside down to remove the logic board/power supply mount.
    댓글 쓰기
  7. Apple TV 4K Power Connector Replacement: 7 단계, 이미지 3개 중 1개 Apple TV 4K Power Connector Replacement: 7 단계, 이미지 3개 중 2개 Apple TV 4K Power Connector Replacement: 7 단계, 이미지 3개 중 3개
    • Disconnect the latch connecting the power connector to the power supply.
    • Feed the wire though the logic board/power supply mount. After this, remove the power connector from the device.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Brian Gehring
회원 가입일: 10/04/18
493 평판
안내서 2개를 작성함
UW Stout, Team S6-G3, Ogden Fall 2018 UW Stout, Team S6-G3, Ogden Fall 2018 회원
UWSTOUT-OGDEN-F18S6G3
4 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 87
전체 시간: 4,396
