주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple Time Capsule Model A1254 Fan Replacement
필요한 것
    1. Apple Time Capsule Model A1254 Fan Replacement, Back Plate: 1 단계, 이미지 3개 중 1개 Apple Time Capsule Model A1254 Fan Replacement, Back Plate: 1 단계, 이미지 3개 중 2개 Apple Time Capsule Model A1254 Fan Replacement, Back Plate: 1 단계, 이미지 3개 중 3개
      • Turn the device upside down to reveal the rubber section of the back plate. Using a metal spudger, carefully wedge the blunt tip into the space between the aluminum back plate and the rubber, separating the two pieces.
      • This may take a few minutes to pry the rubber off completely. Once your are able to get a grip on the rubber it is easier to peel it off using your hands.
      • Depending on air temperature and how set the adhesive is, you may need to spend some time warming the back plate with a hot plate (on low) or hair dryer.
      • Don't worry about re-applying adhesive to the rubber; the remaining adhesive has plenty of strength to affix itself to the aluminum.
      댓글 쓰기
    2. Apple Time Capsule Model A1254 Fan Replacement: 2 단계, 이미지 2개 중 1개 Apple Time Capsule Model A1254 Fan Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the ten 3mm screws with a Phillips #00 screwdriver.
      • The screws with adhesive covering do not need to be removed.
      댓글 쓰기
    3. Apple Time Capsule Model A1254 Fan Replacement: 3 단계, 이미지 2개 중 1개 Apple Time Capsule Model A1254 Fan Replacement: 3 단계, 이미지 2개 중 2개
      • The fan affixed to the back plate is connected to the logic board. A small wire must be detached to fully remove the back plate.
      • Pull the base of the wire close to the logic board and the connector will pop off.
      댓글 쓰기
    1. Apple Time Capsule Model A1254 Fan Replacement, Fan: 4 단계, 이미지 2개 중 1개 Apple Time Capsule Model A1254 Fan Replacement, Fan: 4 단계, 이미지 2개 중 2개
      • Orientate the back plate so that the fan is facing away from you.
      • Use the #0 Phillips Screw Drive to push the rubber shock mounts through the back plate.
      • Make sure that the head of the screw driver is centered on the head of the rubber shock mount so that it doesn't slip off causing possible injury.
      • When attaching the new fan, push the new rubber shock mounts through the back plate first. Attach the fan once all mounts are inserted.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
JR Alfano
회원 가입일: 10/06/16
543 평판
안내서 1개를 작성함
Cal Poly, Team 4-2, Livingston Fall 2016 Cal Poly, Team 4-2, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S4G2
4 회원들
안내서 22개를 작성함
2가이드 댓글
Hi where can I find the new rubber shock mount replacement for A-1254 fan replacement? thx.
V Q - 답글 공유
How do I get the rubber feet off the old fan and put them on the new fan?
Jim Matthews - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 40
전체 시간: 5,372
