주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Arlo Pro 2 Camera Micro-USB Port Replacement
필요한 것
    1. Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Motherboard: 1 단계, 이미지 3개 중 1개 Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Motherboard: 1 단계, 이미지 3개 중 2개 Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Motherboard: 1 단계, 이미지 3개 중 3개
      • Press the release button on the camera and gently pull apart the casing to open the device.
      • Remove the battery from inside the case.
      댓글 쓰기
    2. Arlo Pro 2 Camera Micro-USB Port Replacement: 2 단계, 이미지 3개 중 1개 Arlo Pro 2 Camera Micro-USB Port Replacement: 2 단계, 이미지 3개 중 2개 Arlo Pro 2 Camera Micro-USB Port Replacement: 2 단계, 이미지 3개 중 3개
      • Use a T5 Torx screwdriver to remove the four 7 mm screws securing the camera case.
      • Carefully pull the outside of the case apart from the internal case to remove the camera components from the outside casing.
      댓글 쓰기
    3. Arlo Pro 2 Camera Micro-USB Port Replacement: 3 단계, 이미지 3개 중 1개 Arlo Pro 2 Camera Micro-USB Port Replacement: 3 단계, 이미지 3개 중 2개 Arlo Pro 2 Camera Micro-USB Port Replacement: 3 단계, 이미지 3개 중 3개
      • Use a Phillips #00 screwdriver to remove four 4 mm screws connecting the daughterboards to the motherboard.
      • Seperate the daughterboards from the motherboard and camera casing.
      댓글 쓰기
    4. Arlo Pro 2 Camera Micro-USB Port Replacement: 4 단계, 이미지 3개 중 1개 Arlo Pro 2 Camera Micro-USB Port Replacement: 4 단계, 이미지 3개 중 2개 Arlo Pro 2 Camera Micro-USB Port Replacement: 4 단계, 이미지 3개 중 3개
      • Use a Flathead 4 mm screwdriver to remove the four 7 mm screw posts connecting the motherboard to the case.
      • Carefully pull the motherboard apart from the camera casing.
      댓글 쓰기
    5. Arlo Pro 2 Camera Micro-USB Port Replacement: 5 단계, 이미지 2개 중 1개 Arlo Pro 2 Camera Micro-USB Port Replacement: 5 단계, 이미지 2개 중 2개
      • Disconnect the white cord from the port on the motherboard, by gently pulling away from the port to fully isolate the motherboard from the case.
      댓글 쓰기
    1. Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Micro-USB Port: 6 단계, 이미지 2개 중 1개 Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Micro-USB Port: 6 단계, 이미지 2개 중 2개
      • Thread the wires of the Micro-USB port through the casing.
      • Guide the wiring through the opening so that the wiring is solely in the battery cavity and not going through any part of the case.
      댓글 쓰기
    2. Arlo Pro 2 Camera Micro-USB Port Replacement: 7 단계, 이미지 3개 중 1개 Arlo Pro 2 Camera Micro-USB Port Replacement: 7 단계, 이미지 3개 중 2개 Arlo Pro 2 Camera Micro-USB Port Replacement: 7 단계, 이미지 3개 중 3개
      • Use a Phillips #00 screwdriver to remove two 3 mm screws connecting the Micro-USB port to the camera casing.
      • Gently remove the Micro-USB port by pulling it away from the case.
      댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Ben I.
회원 가입일: 03/26/25
493 평판
안내서 5개를 작성함
UMass Dartmouth, Team 2-2, Botvin Spring 2025 UMass Dartmouth, Team 2-2, Botvin Spring 2025 회원
UMASSD-BOTVIN-S25S2G2
3 회원들
안내서 27개를 작성함
1가이드 댓글
Great guide, I was able to remove the Micro USB Charge Port and Cable from the arlo PRO 2 (Model: VMC4030P) without having to remove the System Board. However finding a replacement part is the tricky part. I stumbled across this guide after removing the cable hoping an iFixIt guide might have a link to a part source.
tech2life - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 53
전체 시간: 409
