주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ArmorAll AA255 Power Cord Replacement
필요한 것
    1. ArmorAll AA255 Power Cord Replacement, Lower Motor Housing: 1 단계, 이미지 1개 중 1개
      • Remove the orange main housing unit from the vacuum bucket by pulling outward on the handle tabs while lifting upward as shown.
      댓글 쓰기
    2. ArmorAll AA255 Power Cord Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the five 15mm PH2 screws.
      댓글 쓰기
    3. ArmorAll AA255 Power Cord Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the 15 mm T20 screw. This screw is located nearest the power cord.
      댓글 쓰기
    4. ArmorAll AA255 Power Cord Replacement: 4 단계, 이미지 2개 중 1개 ArmorAll AA255 Power Cord Replacement: 4 단계, 이미지 2개 중 2개
      • Gently separate the upper and lower sections of the main housing.
      댓글 쓰기
    1. ArmorAll AA255 Power Cord Replacement, Power Cord: 5 단계, 이미지 1개 중 1개
      • Pull the black wire from the power cord out of the switch.
      • There are no clips or tabs that hold this wire in place. Just pull strongly to remove it.
      • Don't remove both black wires. Only the black wire that comes from the power cord itself needs to be removed. The one going to the motor can be left alone.
      댓글 쓰기
    2. ArmorAll AA255 Power Cord Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the five 15mm screws from the plastic motor cover and power cord clamp using a PH2 screwdriver.
      댓글 쓰기
    3. ArmorAll AA255 Power Cord Replacement: 7 단계, 이미지 2개 중 1개 ArmorAll AA255 Power Cord Replacement: 7 단계, 이미지 2개 중 2개
      • Remove the plastic motor cover.
      • Be sure to loosen the white wire from the notch in the plastic motor cover by pulling it upwards.
      댓글 쓰기
    4. ArmorAll AA255 Power Cord Replacement: 8 단계, 이미지 2개 중 1개 ArmorAll AA255 Power Cord Replacement: 8 단계, 이미지 2개 중 2개
      • Detach the white wire from the motor by pulling upwards on the wire as you depress the small metal tab on the connector with a nylon spudger.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Abel Manring
회원 가입일: 02/10/16
263 평판
안내서 1개를 작성함
IUPUI, Team 2-1, Baechle Spring 2016 IUPUI, Team 2-1, Baechle Spring 2016 회원
IUPUI-BAECHLE-S16S2G1
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 36
전체 시간: 1,537
