주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Assemble bObi Pet Post-Repair
필요한 것
    1. Assemble bObi Pet Post-Repair, Connect the Cover: 1 단계, 이미지 2개 중 1개 Assemble bObi Pet Post-Repair, Connect the Cover: 1 단계, 이미지 2개 중 2개
      • Attach the 2 circuit plugs from bObi Pet's cover back onto her main board.
      • The yellow-wired plug connects to the right side of the mainboard.
      • The white-wired plug on bObi Pet’s lid connects to the middle of the mainboard.
      댓글 쓰기
    2. Assemble bObi Pet Post-Repair, Align bObi Pet's Cover: 2 단계, 이미지 3개 중 1개 Assemble bObi Pet Post-Repair, Align bObi Pet's Cover: 2 단계, 이미지 3개 중 2개 Assemble bObi Pet Post-Repair, Align bObi Pet's Cover: 2 단계, 이미지 3개 중 3개
      • Lay down bObi Pet's cover and line up the edges precisely.
      • While holding bObi Pet's top and bottom together, carefully flip her over onto a flat surface.
      댓글 쓰기
    3. Assemble bObi Pet Post-Repair, Replace the Front Wheel: 3 단계, 이미지 3개 중 1개 Assemble bObi Pet Post-Repair, Replace the Front Wheel: 3 단계, 이미지 3개 중 2개 Assemble bObi Pet Post-Repair, Replace the Front Wheel: 3 단계, 이미지 3개 중 3개
      • Reinstall the front wheel’s screw.
      • Then, place the front wheel on top and firmly push down to secure it.
      댓글 쓰기
    4. Assemble bObi Pet Post-Repair, Secure the Cover: 4 단계, 이미지 3개 중 1개 Assemble bObi Pet Post-Repair, Secure the Cover: 4 단계, 이미지 3개 중 2개 Assemble bObi Pet Post-Repair, Secure the Cover: 4 단계, 이미지 3개 중 3개
      • Replace the dustbin’s red fastener and install its 2 screws.
      • Install the 4 screws in the space beneath the brush compartment.
      댓글 쓰기
    5. Assemble bObi Pet Post-Repair, Secure the Brushes on bObi Pet: 5 단계, 이미지 3개 중 1개 Assemble bObi Pet Post-Repair, Secure the Brushes on bObi Pet: 5 단계, 이미지 3개 중 2개 Assemble bObi Pet Post-Repair, Secure the Brushes on bObi Pet: 5 단계, 이미지 3개 중 3개
      • Plug in the brush compartment.
      • Then, replace its red brush fastener and install the 2 screws.
      댓글 쓰기
    6. Assemble bObi Pet Post-Repair, Replace the Bin Holders: 6 단계, 이미지 3개 중 1개 Assemble bObi Pet Post-Repair, Replace the Bin Holders: 6 단계, 이미지 3개 중 2개 Assemble bObi Pet Post-Repair, Replace the Bin Holders: 6 단계, 이미지 3개 중 3개
      • Position the brush compartment back in its original place on bObi Pet.
      • Now reinsert the corner pieces on both sides of the dustbin, with the arms of the brush attachment linked.
      댓글 쓰기
    7. Assemble bObi Pet Post-Repair, Replace the Dustbin: 7 단계, 이미지 3개 중 1개 Assemble bObi Pet Post-Repair, Replace the Dustbin: 7 단계, 이미지 3개 중 2개 Assemble bObi Pet Post-Repair, Replace the Dustbin: 7 단계, 이미지 3개 중 3개
      • Ensure the rubber strip near bObi Pet's dustbin is not stuck underneath the brush compartment. Then, reinstall the 2 screws in each of the corner pieces.
      • Make sure the bin can slide in easily before using bObi Pet again and your repair is complete.
      댓글 쓰기
결론
After completing these steps, your bObi Pet should be back together in working order. Just replace any brushes and filters that may have been removed during disassembly.
Congratulations on completing your repair and happy cleaning!
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Chelsea
회원 가입일: 09/24/14
2,278 평판
안내서 31개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 22
전체 시간: 360
