주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Astak Mole Camera Head Replacement
필요한 것
    1. Astak Mole Camera Head Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
      • Remove the four bottom tabs in order to access the bottom screws.
      댓글 쓰기
    2. Astak Mole Camera Head Replacement: 2 단계, 이미지 1개 중 1개
      • Remove all four 14 mm Phillips #1 screws.
      댓글 쓰기
    3. Astak Mole Camera Head Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the SD card.
      댓글 쓰기
    4. Astak Mole Camera Head Replacement: 4 단계, 이미지 1개 중 1개
      • Pry up the motherboard on the four points using a spudger.
      • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
      댓글 쓰기
    5. Astak Mole Camera Head Replacement: 5 단계, 이미지 1개 중 1개
      • Gently pull back the motherboard to expose many of the component's wired connections.
      댓글 쓰기
    1. Astak Mole Camera Head Replacement, Camera Head: 6 단계, 이미지 1개 중 1개
      • Unscrew the three screws connecting the base to the camera head with the PH1 size Phillips head bit.
      • Screw measurements: Length=7.0mm.
      • The third screw can be exposed by rotating the camera head.
      • Do not force the camera head farther than it will allow you.
      댓글 쓰기
    2. Astak Mole Camera Head Replacement: 7 단계, 이미지 1개 중 1개
      • Unscrew indicated Phillips head screws using the PH1 Phillips head bit to free wires.
      • Screw measurements: Length=3.5mm
      댓글 쓰기
    3. Astak Mole Camera Head Replacement: 8 단계, 이미지 3개 중 1개 Astak Mole Camera Head Replacement: 8 단계, 이미지 3개 중 2개 Astak Mole Camera Head Replacement: 8 단계, 이미지 3개 중 3개
      • Separate the three indicated outputs from the motherboard with metal spudger.
      • There is electrical adhesive on the output. This can be easily separated with the metal spudger.
      댓글 쓰기
    4. Astak Mole Camera Head Replacement: 9 단계, 이미지 1개 중 1개
      • Separate the wire from CPU by cutting adhesive with metal spudger.
      • It is advised to reapply adhesive to wired connections during reassembly, and to re-attach wires to CPU to prevent disconnection and loose wires inside device.
      • Be careful not to damage the CPU in the process. This is not a wired connection.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Bryan
회원 가입일: 09/15/16
104 평판
안내서 1개를 작성함
USF Tampa, Team 2-2, Blackwell Fall 2016 USF Tampa, Team 2-2, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S2G2
4 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 24
전체 시간: 916
