주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Astak Mole Motherboard Replacement
필요한 것
    1. Astak Mole Motherboard Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
      • Remove the four bottom tabs in order to access the bottom screws.
      댓글 쓰기
    2. Astak Mole Motherboard Replacement: 2 단계, 이미지 1개 중 1개
      • Remove all four 14 mm Phillips #1 screws.
      댓글 쓰기
    3. Astak Mole Motherboard Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the SD card.
      댓글 쓰기
    4. Astak Mole Motherboard Replacement: 4 단계, 이미지 1개 중 1개
      • Pry up the motherboard on the four points using a spudger.
      • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
      댓글 쓰기
    5. Astak Mole Motherboard Replacement: 5 단계, 이미지 1개 중 1개
      • Gently pull back the motherboard to expose many of the component's wired connections.
      댓글 쓰기
    1. Astak Mole Motherboard Replacement, Motherboard: 6 단계, 이미지 2개 중 1개 Astak Mole Motherboard Replacement, Motherboard: 6 단계, 이미지 2개 중 2개
      • Sever the indicated adhesive connections to the motherboard allowing the wired connections to be removed.
      • All wired connections to the motherboard are removed by the thin plastic male connector inserted into the larger female plastic connection.
      댓글 쓰기
    2. Astak Mole Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Astak Mole Motherboard Replacement: 7 단계, 이미지 2개 중 2개
      • The red wires may be adhered to the CPU as indicated and will need to be severed as shown.
      • Be careful not to scratch the CPU in this step. This is not a wired connection.
      • Sever the additional adhesive connections so that the wired connections may be removed.
      댓글 쓰기
    3. Astak Mole Motherboard Replacement: 8 단계, 이미지 1개 중 1개
      • Locate and unscrew the indicated screw using the (PH1) Phillips head bit.
      • Screw Measurements: (Length= 5.3mm)
      댓글 쓰기
    4. Astak Mole Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Astak Mole Motherboard Replacement: 9 단계, 이미지 2개 중 2개
      • Remove the last two wired connections to the motherboard by severing the indicated connections.
      • Lift up the secondary motherboard as indicated using the metal spudger.
      • All connections should be severed from the motherboard and a new motherboard may be inserted.
      • It is advised to reapply adhesive to wired connections during reassembly.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Andrew Birch
회원 가입일: 09/15/16
204 평판
안내서 2개를 작성함
USF Tampa, Team 2-2, Blackwell Fall 2016 USF Tampa, Team 2-2, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S2G2
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 31
전체 시간: 942
