주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Astro A40 Gen2 Mixamp Button Replacement
필요한 것
  1. Astro A40 Gen2 Mixamp Button Replacement, Remove Dials: 1 단계, 이미지 3개 중 1개 Astro A40 Gen2 Mixamp Button Replacement, Remove Dials: 1 단계, 이미지 3개 중 2개 Astro A40 Gen2 Mixamp Button Replacement, Remove Dials: 1 단계, 이미지 3개 중 3개
    • Remove the dials using either a metal spudger or your hands. Be careful as the dials may be difficult to remove.
    댓글 쓰기
  2. Astro A40 Gen2 Mixamp Button Replacement, Remove nuts and washers.: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Locate the two 11/32 inch nuts underneath the dials.
    • Use an 11/32 inch socket wrench or tweezers to unscrew and remove the nuts and washers.
    댓글 쓰기
  3. Astro A40 Gen2 Mixamp Button Replacement, Remove back pad.: 3 단계, 이미지 2개 중 1개 Astro A40 Gen2 Mixamp Button Replacement, Remove back pad.: 3 단계, 이미지 2개 중 2개
    • Using a larger metal spudger, remove the rubber back of the mixamp.
    • The back will have glue residue after removal. Depending on the stickiness of the residue, more glue may be needed to stick the backing back on.
    댓글 쓰기
  4. Astro A40 Gen2 Mixamp Button Replacement, Take out main case screw.: 4 단계, 이미지 1개 중 1개
    • Remove the one 4.5 mm Phillips #0 screw on the back panel of the mixamp.
    댓글 쓰기
  5. Astro A40 Gen2 Mixamp Button Replacement, Pry open the case.: 5 단계, 이미지 3개 중 1개 Astro A40 Gen2 Mixamp Button Replacement, Pry open the case.: 5 단계, 이미지 3개 중 2개 Astro A40 Gen2 Mixamp Button Replacement, Pry open the case.: 5 단계, 이미지 3개 중 3개
    • Using a large metal spudger, detach all plastic clips holding the bottom and top casings together.
    • Remove the input casing using your fingers.
    • Be careful when releasing the clips between the two casings, as it is very easy to scratch the mixamp or break the clips.
    • Use caution when pulling the two casings apart as it is very easy to pinch your fingers between them.
    댓글 쓰기
  6. Astro A40 Gen2 Mixamp Button Replacement, Remove the motherboard from the case.: 6 단계, 이미지 1개 중 1개
    • Remove the four 5.8 mm Phillips #0 screws on the motherboard.
    댓글 쓰기
  7. Astro A40 Gen2 Mixamp Button Replacement: 7 단계, 이미지 2개 중 1개 Astro A40 Gen2 Mixamp Button Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the motherboard from the casing.
    댓글 쓰기
  8. Astro A40 Gen2 Mixamp Button Replacement, Mixamp Button: 8 단계, 이미지 2개 중 1개 Astro A40 Gen2 Mixamp Button Replacement, Mixamp Button: 8 단계, 이미지 2개 중 2개
    • Use a metal spudger to pry off the buttons and remove them.
    • You may need to apply pressure to break off the small black caps which hold the buttons down. The buttons will still function without the black caps.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Mark
회원 가입일: 01/22/15
412 평판
안내서 3개를 작성함
Cal Poly, Team 20-18, Maness Winter 2015 Cal Poly, Team 20-18, Maness Winter 2015 회원
CPSU-MANESS-W15S20G18
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 26
전체 시간: 2,644
