주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Astro A50 Channel Selection Switch Replacement
필요한 것
    1. Astro A50 Channel Selection Switch Replacement, Channel Selection Switch: 1 단계, 이미지 2개 중 1개 Astro A50 Channel Selection Switch Replacement, Channel Selection Switch: 1 단계, 이미지 2개 중 2개
      • Remove the foam ear padding by pulling it straight to you
      댓글 쓰기
    2. Astro A50 Channel Selection Switch Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the four 3.5mm Phillips head screws circled in red, and remove the grey cover.
      댓글 쓰기
    3. Astro A50 Channel Selection Switch Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the four 3.5mm Phillips head screws circled in red and remove the silver cover.
      댓글 쓰기
    4. Astro A50 Channel Selection Switch Replacement: 4 단계, 이미지 2개 중 1개 Astro A50 Channel Selection Switch Replacement: 4 단계, 이미지 2개 중 2개
      • Remove the four 3.5mm Phillips head screws.
      • Remove the 3.5mm Phillips head screw circled in blue to remove secondary motherboard.
      댓글 쓰기
    5. Astro A50 Channel Selection Switch Replacement: 5 단계, 이미지 1개 중 1개
      • Separate the secondary mother board from the motherboard by pulling firmly to the right on the white connector.
      댓글 쓰기
    6. Astro A50 Channel Selection Switch Replacement: 6 단계, 이미지 1개 중 1개
      • Finally push the channel selector in towards the motherboard to remove it from the headset casing. The switch is pointed to by the screwdriver inside the red square.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
William Czerwonka
회원 가입일: 09/21/17
228 평판
안내서 2개를 작성함
IUPUI, Team S1-G1, Baechle Fall 2017 IUPUI, Team S1-G1, Baechle Fall 2017 회원
IUPUI-BAECHLE-F17S1G1
2 회원들
안내서 20개를 작성함
3가이드 댓글
This is great, thank you. My switch has been broken for two years, now I can get to fixing it.
Question: Once we have taken it apart, do we simply replace the switch or is there a contact on the switch itself, PCB or wire that needs to be re-attached or adjusted?
Thanks!
-Brandon
Brandon Thomas - 답글 공유
where did you get the part to replace it? Can’t find just the little switch anywhere.
Justin Sykes - 답글 공유
This is perfect. But where do you get a new switch? Can’t find just the tiny part anywhere.
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 21
전체 시간: 2,771
