주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus 1015E-DS03 Screen Replacement
필요한 것
  1. Asus 1015E-DS03 Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Hold the laptop using both hands with the battery facing upwards.
    댓글 쓰기
  2. Asus 1015E-DS03 Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Push the two tabs located below the battery in towards each other using your thumbs.
    댓글 쓰기
  3. Asus 1015E-DS03 Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Push the battery upwards and out of the laptop as shown.
    댓글 쓰기
  4. Asus 1015E-DS03 Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Continue to push the battery upwards until it is completely separated from the laptop as shown.
    댓글 쓰기
  5. Asus 1015E-DS03 Screen Replacement, Front Screen Case: 5 단계, 이미지 1개 중 1개
    • Push up on the back of the tabs that cover the hinges connecting the screen to the base of the laptop.
    • While pushing up on the back of the tabs, insert the spudger into the opening created from pushing on the tabs until the tab detaches.
    댓글 쓰기
  6. Asus 1015E-DS03 Screen Replacement: 6 단계, 이미지 2개 중 1개 Asus 1015E-DS03 Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Once the case has been separated from the laptop, pull the case off completely, using the plastic opening tool or your fingers.
    • You will hear popping noises which are to be expected.
    댓글 쓰기
  7. Asus 1015E-DS03 Screen Replacement: 7 단계, 이미지 1개 중 1개
    • When the screen case has been successfully removed, the laptop should resemble the photo shown here.
    댓글 쓰기
  8. Asus 1015E-DS03 Screen Replacement, Screen: 8 단계, 이미지 1개 중 1개
    • Unscrew the 3 mm screws (4) using a #0 Phillips head screwdriver.
    댓글 쓰기
  9. Asus 1015E-DS03 Screen Replacement: 9 단계, 이미지 2개 중 1개 Asus 1015E-DS03 Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Lift the screen away from the computer.
    • Be careful removing the screen, as the left side is still connected to the computer.
    댓글 쓰기
  10. Asus 1015E-DS03 Screen Replacement: 10 단계, 이미지 2개 중 1개 Asus 1015E-DS03 Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the wire that is glued to the back of the screen with your fingers.
    • Remove the tape covering the connection port.
    댓글 쓰기
  11. Asus 1015E-DS03 Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Separate the screen from the computer by gently pulling it out.
    댓글 쓰기
  12. Asus 1015E-DS03 Screen Replacement: 12 단계, 이미지 1개 중 1개
    • Upon removal, the computer should look like this picture.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Becca Day
회원 가입일: 03/23/16
321 평판
안내서 2개를 작성함
Clemson, Team 7-4, Benson Spring 2016 Clemson, Team 7-4, Benson Spring 2016 회원
CLEM-BENSON-S16S7G4
5 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 49
전체 시간: 1,096
