주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus 1015E-DS03 Trackpad Replacement
필요한 것
  1. Asus 1015E-DS03 Trackpad Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Hold the laptop using both hands with the battery facing upwards.
    댓글 쓰기
  2. Asus 1015E-DS03 Trackpad Replacement: 2 단계, 이미지 1개 중 1개
    • Push the two tabs located below the battery in towards each other using your thumbs.
    댓글 쓰기
  3. Asus 1015E-DS03 Trackpad Replacement: 3 단계, 이미지 1개 중 1개
    • Push the battery upwards and out of the laptop as shown.
    댓글 쓰기
  4. Asus 1015E-DS03 Trackpad Replacement: 4 단계, 이미지 1개 중 1개
    • Continue to push the battery upwards until it is completely separated from the laptop as shown.
    댓글 쓰기
  5. Asus 1015E-DS03 Trackpad Replacement, Keyboard: 5 단계, 이미지 1개 중 1개
    • Once the battery is removed, unscrew the highlighted 3mm screws (4) using a #0 Phillps head screwdriver.
    • Be very careful not to lose the screws, these four screws are very small.
    댓글 쓰기
  6. Asus 1015E-DS03 Trackpad Replacement: 6 단계, 이미지 2개 중 1개 Asus 1015E-DS03 Trackpad Replacement: 6 단계, 이미지 2개 중 2개
    • After all four screws are removed, flip the laptop over with the keyboard facing up.
    • Use a spudger to pry up where the keyboard is attached to the laptop on all sides until it is detached from the laptop.
    • It is normal to hear cracking noises when prying off the keyboard.
    • After keyboard is detached from laptop, there is a ribbon cable still attached to the motherboard. See next step before completely removing keyboard.
    댓글 쓰기
  7. Asus 1015E-DS03 Trackpad Replacement: 7 단계, 이미지 1개 중 1개
    • After the keyboard is detached, the ribbon cable which connects the keyboard to the laptop's motherboard is exposed.
    • Be careful not to tear or rip the ribbon cable.
    댓글 쓰기
  8. Asus 1015E-DS03 Trackpad Replacement: 8 단계, 이미지 1개 중 1개
    • Using the spudger push the white clips upwards that are holding the cable.
    댓글 쓰기
  9. Asus 1015E-DS03 Trackpad Replacement: 9 단계, 이미지 2개 중 1개 Asus 1015E-DS03 Trackpad Replacement: 9 단계, 이미지 2개 중 2개
    • Gently pull the strip out of the square slot.
    댓글 쓰기
  10. Asus 1015E-DS03 Trackpad Replacement, Trackpad: 10 단계, 이미지 1개 중 1개
    • Unscrew all of the indicated 5mm screws (11) using a #0 Philips head screwdriver.
    • One of the screws will be covered by a sticker indicating that proceeding will void the warranty.
    댓글 쓰기
  11. Asus 1015E-DS03 Trackpad Replacement: 11 단계, 이미지 2개 중 1개 Asus 1015E-DS03 Trackpad Replacement: 11 단계, 이미지 2개 중 2개
    • Before the baseboard can be fully removed from the laptop, you need to detach the small blue tab attached to the motherboard.
    • Gently lift up on the black plastic tab that is securing the blue tab in place.
    • Carefully pull the blue tab out of the dock.
    댓글 쓰기
  12. Asus 1015E-DS03 Trackpad Replacement: 12 단계, 이미지 2개 중 1개 Asus 1015E-DS03 Trackpad Replacement: 12 단계, 이미지 2개 중 2개
    • Use the spudger from the laptop to 'pop' open the track-pad base, starting from the corner shown
    • Once the corner is popped it may be easier to use your fingers to pop off the entire track-pad base
    • You will hear popping. Although this is normal, use caution pulling the track-pad base from the rest of the laptop
    댓글 쓰기
  13. Asus 1015E-DS03 Trackpad Replacement: 13 단계, 이미지 3개 중 1개 Asus 1015E-DS03 Trackpad Replacement: 13 단계, 이미지 3개 중 2개 Asus 1015E-DS03 Trackpad Replacement: 13 단계, 이미지 3개 중 3개
    • Once the trackpad base is detached, flip it face-down.
    • Lift the small black tab that the blue flat cable is attached to.
    댓글 쓰기
  14. Asus 1015E-DS03 Trackpad Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the 3mm screws (3) circled in red with a #0 Phillips head screwdriver.
    • The metal plate shown in blue will fall off by itself, replace it before re-securing the baseplate.
    댓글 쓰기
  15. Asus 1015E-DS03 Trackpad Replacement: 15 단계, 이미지 3개 중 1개 Asus 1015E-DS03 Trackpad Replacement: 15 단계, 이미지 3개 중 2개 Asus 1015E-DS03 Trackpad Replacement: 15 단계, 이미지 3개 중 3개
    • Detach the tape connecting the trackpad to the trackpad base, and carefully remove the trackpad.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Liam Monteith
회원 가입일: 03/21/16
149 평판
안내서 1개를 작성함
Clemson, Team 7-4, Benson Spring 2016 Clemson, Team 7-4, Benson Spring 2016 회원
CLEM-BENSON-S16S7G4
5 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 59
전체 시간: 909
