주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus A52F Cooling System Replacement
필요한 것
  1. Asus A52F Cooling System Replacement, Battery: 1 단계, 이미지 2개 중 1개 Asus A52F Cooling System Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Place the laptop face down with the battery facing away from you.
    • Locate the two buttons next to the battery.
    • Slide the right slider to the unlocked (red) position.
    댓글 쓰기
  2. Asus A52F Cooling System Replacement: 2 단계, 이미지 2개 중 1개 Asus A52F Cooling System Replacement: 2 단계, 이미지 2개 중 2개
    • Hold the left button to the left.
    • Slide the battery with your other hand away from you and it should disconnect.
    댓글 쓰기
  3. Asus A52F Cooling System Replacement, Lower Case: 3 단계, 이미지 3개 중 1개 Asus A52F Cooling System Replacement, Lower Case: 3 단계, 이미지 3개 중 2개 Asus A52F Cooling System Replacement, Lower Case: 3 단계, 이미지 3개 중 3개
    • Remove the five Phillips # 0 screws from the back panel.
    • Using your finger or a plastic spudger start to carefully pry up the back planel.
    댓글 쓰기
  4. Asus A52F Cooling System Replacement: 4 단계, 이미지 2개 중 1개 Asus A52F Cooling System Replacement: 4 단계, 이미지 2개 중 2개
    • Slide the back panel away and remove the panel.
    댓글 쓰기
  5. Asus A52F Cooling System Replacement, Cooling System: 5 단계, 이미지 2개 중 1개 Asus A52F Cooling System Replacement, Cooling System: 5 단계, 이미지 2개 중 2개
    • Removal of cooling system will void your warranty. Proceed with caution.
    댓글 쓰기
  6. Asus A52F Cooling System Replacement: 6 단계, 이미지 2개 중 1개 Asus A52F Cooling System Replacement: 6 단계, 이미지 2개 중 2개
    • Using a Phillips #0 screwdriver, remove all six screws from the cooling system.
    • Unplug the fan power connector.
    댓글 쓰기
  7. Asus A52F Cooling System Replacement: 7 단계, 이미지 2개 중 1개 Asus A52F Cooling System Replacement: 7 단계, 이미지 2개 중 2개
    • Carefully grab the copper pipe and start to lift upward.
    • Lift to the angle shown and then start to slide it out.
    댓글 쓰기
  8. Asus A52F Cooling System Replacement: 8 단계, 이미지 1개 중 1개
    • Clean the designated area with isopropyl alcohol on a microfiber cloth
    • Replace with new thermal paste if needed
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Bradley Varnum
회원 가입일: 03/09/17
345 평판
안내서 2개를 작성함
UMass Dartmouth, Team S5-G1, Botvin Spring 2017 UMass Dartmouth, Team S5-G1, Botvin Spring 2017 회원
UMASSD-BOTVIN-S17S5G1
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 19
전체 시간: 1,294
