주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus A53U-ES21 Keyboard Replacement
필요한 것
  1. Asus A53U-ES21 Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 Asus A53U-ES21 Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Make sure the laptop is off.
    • Flip the laptop upside down so that the battery is facing you.
    댓글 쓰기
  2. Asus A53U-ES21 Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Asus A53U-ES21 Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Move the two sliders towards the outer edge of the laptop.
    • Pull the battery out with your left hand while holding the right slider.
    댓글 쓰기
  3. Asus A53U-ES21 Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 1개 Asus A53U-ES21 Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 2개 Asus A53U-ES21 Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 3개
    • Remove the RAM cover from the bottom of the keyboard.
    • Remove the 5mm screw keeping the panel in place using a Phillips #1 screwdriver.
    • Work the pry tool along the edge to finish removal.
    • Unscrew the two 7mm screws marked with an engraved "K" using a #1 Phillips screwdriver.
    댓글 쓰기
  4. Asus A53U-ES21 Keyboard Replacement: 4 단계, 이미지 3개 중 1개 Asus A53U-ES21 Keyboard Replacement: 4 단계, 이미지 3개 중 2개 Asus A53U-ES21 Keyboard Replacement: 4 단계, 이미지 3개 중 3개
    • Orient the computer so the keyboard is facing toward you with the screen at the top.
    • Find the three buttons to depress at top of the keyboard, set in the crack between the casing and the keyboard, highlighted here in red.
    • Use the pry tool to depress the buttons. The keyboard should pop out.
    댓글 쓰기
  5. Asus A53U-ES21 Keyboard Replacement: 5 단계, 이미지 3개 중 1개 Asus A53U-ES21 Keyboard Replacement: 5 단계, 이미지 3개 중 2개 Asus A53U-ES21 Keyboard Replacement: 5 단계, 이미지 3개 중 3개
    • Fold the keyboard out towards you. It should still be connected by a ribbon to the rest of the computer.
    • Gently use the opening tool to lift the black piece holding the ribbon down and remove the ribbon.
    • The black piece should cover the white line on the ribbon when it is replaced.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Mabel Trager
회원 가입일: 10/23/18
180 평판
안내서 1개를 작성함
UMass Dartmouth, Team S1-G3, Simcock Fall 2018 UMass Dartmouth, Team S1-G3, Simcock Fall 2018 회원
UMASSD-SIMCOCK-F18S1G3
3 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 27
전체 시간: 916
