주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus Chromebook C201 Keyboard Replacement
필요한 것
  1. Asus Chromebook C201 Keyboard Replacement, Palm Rest Assembly: 1 단계, 이미지 1개 중 1개
    • Flip the laptop upside down with the rear end of the computer away from you.
    댓글 쓰기
  2. Asus Chromebook C201 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two rear rubber feet by using one of the small, blue plastic spudgers.
    댓글 쓰기
  3. Asus Chromebook C201 Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Use the J0 screwdriver to remove the eight 5mm black screws on the bottom of the laptop, which includes the two that were hidden under the rear rubber feet.
    댓글 쓰기
  4. Asus Chromebook C201 Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Turn the laptop on its side. Use a small, blue opening tool to pry the keyboard cover and laptop apart. Begin from the top right, next to the power button, and slowly work your way around to the opposite side until the keyboard cover is detached.
    댓글 쓰기
  5. Asus Chromebook C201 Keyboard Replacement: 5 단계, 이미지 2개 중 1개 Asus Chromebook C201 Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Gently flip the keyboard cover away from the laptop. Rest it safely upside down so the cables are not strained and are easily accessible.
    댓글 쓰기
  6. Asus Chromebook C201 Keyboard Replacement: 6 단계, 이미지 3개 중 1개 Asus Chromebook C201 Keyboard Replacement: 6 단계, 이미지 3개 중 2개 Asus Chromebook C201 Keyboard Replacement: 6 단계, 이미지 3개 중 3개
    • Use the metal spudger to gently pry up the small tabs that are clamping down on the keyboard cables.
    댓글 쓰기
  7. Asus Chromebook C201 Keyboard Replacement: 7 단계, 이미지 2개 중 1개 Asus Chromebook C201 Keyboard Replacement: 7 단계, 이미지 2개 중 2개
    • Carefully pull the keyboard cables out of the connecting ports that are attached to the motherboard.
    댓글 쓰기
  8. Asus Chromebook C201 Keyboard Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the keyboard cover and safely place it somewhere face down.
    댓글 쓰기
  9. Asus Chromebook C201 Keyboard Replacement, Keyboard: 9 단계, 이미지 1개 중 1개
    • Use a J0 screwdriver to remove the two 3mm JIS 0 keyboard screws.
    댓글 쓰기
  10. Asus Chromebook C201 Keyboard Replacement: 10 단계, 이미지 1개 중 1개
    • Pull the tape connecting the keys from the palm rest assembly.
    댓글 쓰기
  11. Asus Chromebook C201 Keyboard Replacement: 11 단계, 이미지 2개 중 1개 Asus Chromebook C201 Keyboard Replacement: 11 단계, 이미지 2개 중 2개
    • Gently, with force, pop the keyboard from the palm rest assembly.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Robert Lawson
회원 가입일: 02/09/16
841 평판
안내서 3개를 작성함
USF Tampa, Team 2-51, Cagle Spring 2016 USF Tampa, Team 2-51, Cagle Spring 2016 회원
USFT-CAGLE-S16S2G51
4 회원들
안내서 10개를 작성함
2가이드 댓글
Thanks!
Took me about 30 minutes, despite losing a couple of screws (which I did find on the floor/chair), interruptions from kids, and forgetting to put a little rubber pad on the new keyboard, requiring almost complete re-disassembly and assembly.
Only real issue I had was that the old keyboard coming out was basically snapping off little bits of the white keyboard case. (The “gently with force” section.) I suspect that it’s designed as a one-way connection and removal will break those little snaps irrespective of what care is taken. But reassembling it seems to work without those snaps just fine.
Thanks!
Jake - 답글 공유
A couple more notes:
I did it without removing the cable for the touchpad at all. I didn’t see any reason to disconnect that.
After examining the old keyboard more carefully, I realized the plastic sheet on the bottom was removable (it’s just glued on) and should be affixed to the bottom of the old one, so once more I took it apart and added that back. (That sheet had probably saved the computer from killing more than the keyboard when coffee was spilled.)
Also, the two slightly longer screws go under the rubber feet.
Jake - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 30
전체 시간: 5,422
