주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus Eee PC 1000HE Keyboard Replacement
필요한 것
  1. Asus Eee PC 1000HE Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Lay the laptop down with the bottom facing upwards.
    • Locate the two battery lock slide tabs.
    댓글 쓰기
  2. Asus Eee PC 1000HE Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Asus Eee PC 1000HE Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the tabs outward to unlock the battery.
    • The right tab will remain in the unlocked position while the left tab must be held.
    • While holding the left tab outward, slide the battery away from you to remove it.
    댓글 쓰기
  3. Asus Eee PC 1000HE Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 1개 Asus Eee PC 1000HE Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 2개 Asus Eee PC 1000HE Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 3개
    • The keyboard will still be attached to the body of the netbook at the conclusion of this step through a ribbon cable located at the bottom edge of the keyboard. Improper removal may result in damage to your device.
    • Identify the four connection points holding the top of the keyboard to the main body of the netbook. To remove the keyboard, use the spudger to unhook the keyboard upwards at these points.
    • The keyboard will become more disconnected as you use the spudger at each connection point.
    댓글 쓰기
  4. Asus Eee PC 1000HE Keyboard Replacement: 4 단계, 이미지 3개 중 1개 Asus Eee PC 1000HE Keyboard Replacement: 4 단계, 이미지 3개 중 2개 Asus Eee PC 1000HE Keyboard Replacement: 4 단계, 이미지 3개 중 3개
    • Flip the keyboard over by pulling the top edge of the keyboard away from the netbook body, using the bottom edge as a hinge point.
    • Locate the opaque strip, or ribbon cable, connecting the back of the keyboard to the hardware of the netbook.
    • To disconnect the ribbon cable, use a plastic opening tool to pull each side of the black plastic strip, located below the ribbon cable, away from the ribbon cable.
    • The black strip will disconnect completely from the ribbon cable. The keyboard will then be detached from the netbook's body and can be safely removed.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Mike Glenn
회원 가입일: 03/21/16
1,026 평판
안내서 8개를 작성함
Clemson, Team 6-2, Benson Spring 2016 Clemson, Team 6-2, Benson Spring 2016 회원
CLEM-BENSON-S16S6G2
4 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 20
전체 시간: 1,446
