주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus Eee PC 1008ha Screen Replacement
필요한 것
    1. Asus Eee PC 1008ha Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Using the plastic opening tool, carefully pry the top panel from the base.
      댓글 쓰기
    2. Asus Eee PC 1008ha Screen Replacement: 2 단계, 이미지 3개 중 1개 Asus Eee PC 1008ha Screen Replacement: 2 단계, 이미지 3개 중 2개 Asus Eee PC 1008ha Screen Replacement: 2 단계, 이미지 3개 중 3개
      • Lift the side of the keyboard.
      • Disconnect the attached ribbon located underneath the keyboard.
      • Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
      댓글 쓰기
    3. Asus Eee PC 1008ha Screen Replacement: 3 단계, 이미지 2개 중 1개 Asus Eee PC 1008ha Screen Replacement: 3 단계, 이미지 2개 중 2개
      • Use your fingers to lift the battery and gently disconnect the wires from the base.
      댓글 쓰기
    1. Asus Eee PC 1008ha Screen Replacement, LCD Screen: 4 단계, 이미지 2개 중 1개 Asus Eee PC 1008ha Screen Replacement, LCD Screen: 4 단계, 이미지 2개 중 2개
      • Using the Phillips #00 screwdriver, unscrew the 4mm screws from the rightmost circuit board.
      • Carefully pull the circuit board away from side of device base.
      댓글 쓰기
    2. Asus Eee PC 1008ha Screen Replacement: 5 단계, 이미지 3개 중 1개 Asus Eee PC 1008ha Screen Replacement: 5 단계, 이미지 3개 중 2개 Asus Eee PC 1008ha Screen Replacement: 5 단계, 이미지 3개 중 3개
      • Using the Phillips #00 screwdriver, unscrew the 4mm screws attaching screen to base from both sides.
      • Gently lift the screen portion from the base.
      댓글 쓰기
    3. Asus Eee PC 1008ha Screen Replacement: 6 단계, 이미지 2개 중 1개 Asus Eee PC 1008ha Screen Replacement: 6 단계, 이미지 2개 중 2개
      • Using the Plastic Opening Tool, pry the six small chits from the face of the screen portion.
      • Using the Phillips #00 screwdriver, unscrew the two 2mm and four 4mm screws from underneath the chits.
      댓글 쓰기
    4. Asus Eee PC 1008ha Screen Replacement: 7 단계, 이미지 2개 중 1개 Asus Eee PC 1008ha Screen Replacement: 7 단계, 이미지 2개 중 2개
      • Slide the Plastic Opening Tool under the edge of the screen bezel to release the front panel of the screen.
      댓글 쓰기
    5. Asus Eee PC 1008ha Screen Replacement: 8 단계, 이미지 2개 중 1개 Asus Eee PC 1008ha Screen Replacement: 8 단계, 이미지 2개 중 2개
      • Using the Phillips #00 screwdriver, unscrew the 2mm screws from the perimeter of the screen.
      • Use your fingers to hold the screen and carefully lift it from the base.
      댓글 쓰기
    6. Asus Eee PC 1008ha Screen Replacement: 9 단계, 이미지 2개 중 1개 Asus Eee PC 1008ha Screen Replacement: 9 단계, 이미지 2개 중 2개
      • Use your fingers to peel back the adhesive tape located on the back of the screen.
      • Disconnect the wire from the screen.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Michael Dooley
회원 가입일: 04/18/13
138 평판
안내서 3개를 작성함
Cal Poly, Team 21-52, Johann Spring 2013 Cal Poly, Team 21-52, Johann Spring 2013 회원
CPSU-JOHANN-S13S21G52
4 회원들
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 40
전체 시간: 3,530
