주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus F6A-X2 Hard Drive Replacement
필요한 것
  1. Asus F6A-X2 Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove any power cords and turn the laptop off. Attempting to replace part of the laptop while power is running through it may cause electrocution or damage to the device.
    • Flip laptop face down and rotate so the battery is facing toward you.
    • The battery is not shown in this picture.
    • To remove the battery, place one finger on each of the two black slide tabs. Push each tab toward the center of the laptop to release the lock.
    • Slide the battery toward you and lift it out of the laptop.
    댓글 쓰기
  2. Asus F6A-X2 Hard Drive Replacement, Back Access Panel: 2 단계, 이미지 2개 중 1개 Asus F6A-X2 Hard Drive Replacement, Back Access Panel: 2 단계, 이미지 2개 중 2개
    • With the laptop facing down, rotate it so the battery pack is facing away from you.
    • Remove the six 1.5 mm Phillips #1 screws on the back panel of the laptop.
    댓글 쓰기
  3. Asus F6A-X2 Hard Drive Replacement: 3 단계, 이미지 3개 중 1개 Asus F6A-X2 Hard Drive Replacement: 3 단계, 이미지 3개 중 2개 Asus F6A-X2 Hard Drive Replacement: 3 단계, 이미지 3개 중 3개
    • Insert a finger into one of the slots on the bottom panel.
    • Gently lift the upwards, and the back panel of the laptop will come off easily.
    댓글 쓰기
  4. Asus F6A-X2 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2개 중 1개 Asus F6A-X2 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2개 중 2개
    • Rotate the laptop 90 degrees towards you so that you are looking at the empty battery compartment.
    댓글 쓰기
  5. Asus F6A-X2 Hard Drive Replacement: 5 단계, 이미지 2개 중 1개 Asus F6A-X2 Hard Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the 2.0 mm Phillips #3 screw located beneath the battery compartment.
    댓글 쓰기
  6. Asus F6A-X2 Hard Drive Replacement: 6 단계, 이미지 3개 중 1개 Asus F6A-X2 Hard Drive Replacement: 6 단계, 이미지 3개 중 2개 Asus F6A-X2 Hard Drive Replacement: 6 단계, 이미지 3개 중 3개
    • Lay the laptop flat on its back.
    • Gently pull left on the black tab, located on the left side of the hard drive, until it pops out.
    • Slowly lift the tab up and pull the hard drive out of the laptop.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jonathan
회원 가입일: 04/24/14
1,174 평판
안내서 11개를 작성함
Cal Poly, Team 10-56, Amido Spring 2014 Cal Poly, Team 10-56, Amido Spring 2014 회원
CPSU-AMIDO-S14S10G56
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 34
전체 시간: 1,209
