주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus G74SX-BBK7 Screen Replacement
필요한 것
  1. Asus G74SX-BBK7 Screen Replacement, Screen: 1 단계, 이미지 2개 중 1개 Asus G74SX-BBK7 Screen Replacement, Screen: 1 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Begin by removing the six square rubber pads around the edge of the frame. These cover the screws to remove the outer frame. They can be taken out by hand or with a pair of tweezers.
    • The squares are attached by a light adhesive which may need to be replaced if it wears off due to constant removal
    • Next, remove the six 6mm Phillip #0 screws from the frame using a Phillips #0 screwdriver.
    댓글 쓰기
  2. Asus G74SX-BBK7 Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Use a spudger to remove the frame. It should come off easier at the top than the bottom so start at the top and work your way down.
    • Be careful when prying off frame so as not to damage the screen or the frame itself.
    댓글 쓰기
  3. Asus G74SX-BBK7 Screen Replacement: 3 단계, 이미지 2개 중 1개 Asus G74SX-BBK7 Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the two 6mm Phillips #0 screws from the top left and right corners using a Phillips #0 screwdriver.
    • Gently lift the top bracket off of the screen and set it aside.
    댓글 쓰기
  4. Asus G74SX-BBK7 Screen Replacement: 4 단계, 이미지 3개 중 1개 Asus G74SX-BBK7 Screen Replacement: 4 단계, 이미지 3개 중 2개 Asus G74SX-BBK7 Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Repeat the last step with the bottom bracket, removing eight 6 mm Phillips #0 screws using a Phillips #0 screwdriver. Set the bracket aside.
    댓글 쓰기
  5. Asus G74SX-BBK7 Screen Replacement: 5 단계, 이미지 3개 중 1개 Asus G74SX-BBK7 Screen Replacement: 5 단계, 이미지 3개 중 2개 Asus G74SX-BBK7 Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Remove four 6mm Phillips #0 screws from the hinges at the bottom of the screen using a Phillips #0 screwdriver.
    • The top section of the laptop will no longer be attached, so gently lay it back on the table.
    댓글 쓰기
  6. Asus G74SX-BBK7 Screen Replacement: 6 단계, 이미지 2개 중 1개 Asus G74SX-BBK7 Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the two 6mm Phillips #0 screws on either side of the screen using a Phillips #0 screwdriver.
    댓글 쓰기
  7. Asus G74SX-BBK7 Screen Replacement: 7 단계, 이미지 2개 중 1개 Asus G74SX-BBK7 Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the screen from the laptop casing and flip it over. Peel the sticker above the connector back and firmly pull the connector out.
    댓글 쓰기
  8. Asus G74SX-BBK7 Screen Replacement: 8 단계, 이미지 2개 중 1개 Asus G74SX-BBK7 Screen Replacement: 8 단계, 이미지 2개 중 2개
    • The last step is to remove eight 3mm Phillip #0 screws from both side brackets of the screen itself using a Phillips #0 screwdriver. There are four screws on each side.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Ryan Lawrence
회원 가입일: 04/14/15
611 평판
안내서 5개를 작성함
Cal Poly, Team 5-10, Maness Spring 2015 Cal Poly, Team 5-10, Maness Spring 2015 회원
CPSU-MANESS-S15S5G10
4 회원들
안내서 6개를 작성함
1가이드 댓글
I replace a motherboard in computer AND W0NT SHOW 0N THE SCREEN BUT IT DOSE TURN ON
nicholasvotolato - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 46
전체 시간: 2,736
