주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus MeMO Pad 7 ME170C Motherboard Replacement
필요한 것
    1. Asus MeMO Pad 7 ME170C  Motherboard  Replacement, Motherboard: 1 단계, 이미지 3개 중 1개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement, Motherboard: 1 단계, 이미지 3개 중 2개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement, Motherboard: 1 단계, 이미지 3개 중 3개
      • Power off the device before disassembly.
      • Be gentle; excessive force can result in a damaged or cracked screen.
      • Gently pry a Jimmy all around the seam of the device until the back panel detaches.
      댓글 쓰기
    2. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 2 단계, 이미지 3개 중 1개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 2 단계, 이미지 3개 중 2개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 2 단계, 이미지 3개 중 3개
      • Use an iFixit opening tool to gently push the black bundle cable connector in a forward motion until it loosens without pushing down on the bundle cable connector.
      댓글 쓰기
    3. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 3 단계, 이미지 3개 중 1개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 3 단계, 이미지 3개 중 2개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 3 단계, 이미지 3개 중 3개
      • Use the plastic opening tool to pry around the edges of the battery.
      • The battery should be laying freely in its port.
      • Lift the battery out of its port.
      댓글 쓰기
    4. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 4 단계, 이미지 3개 중 1개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 4 단계, 이미지 3개 중 2개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 4 단계, 이미지 3개 중 3개
      • Use a plastic opening tool to slide the white cable connector completely out of the port.
      댓글 쓰기
    5. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 5 단계, 이미지 3개 중 1개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 5 단계, 이미지 3개 중 2개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 5 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Flip up the beige clip to loosen the cable.
      • Use the wide nosed tweezers to pinch the blue tab attached to the ribbon cable.
      • Pull the blue tab gently in a lateral motion until it is completely out of its port.
      댓글 쓰기
    6. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 6 단계, 이미지 3개 중 1개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 6 단계, 이미지 3개 중 2개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 6 단계, 이미지 3개 중 3개
      • Use the wide nosed tweezers to gently pull out the orange ribbon inserted in the port on the motherboard.
      댓글 쓰기
    7. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 7 단계, 이미지 3개 중 1개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 7 단계, 이미지 3개 중 2개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 7 단계, 이미지 3개 중 3개
      • Use a plastic opening tool to push the white cable connector out of its port in a side to side motion.
      댓글 쓰기
    8. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 8 단계, 이미지 2개 중 1개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 8 단계, 이미지 2개 중 2개
      • Use the Phillips #000 screwdriver to unscrew the seven screws.
      • There should be two silver and five black screws.
      댓글 쓰기
    9. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 9 단계, 이미지 2개 중 1개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 9 단계, 이미지 2개 중 2개
      • Once the screws are removed, the speaker component will be loosely laying in the track.
      • Use the metal spudger tool to remove the speaker by gently lifting the edge of it.
      댓글 쓰기
    10. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 10 단계, 이미지 3개 중 1개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 10 단계, 이미지 3개 중 2개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 10 단계, 이미지 3개 중 3개
      • Remove the silver tape on one corner with the needle nosed tweezers, and remove the tape from the motherboard.
      댓글 쓰기
    11. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 11 단계, 이미지 3개 중 1개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 11 단계, 이미지 3개 중 2개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 11 단계, 이미지 3개 중 3개
      • Use the needle nosed tweezers to gently pull both of the orange ribbon cables out of their ports.
      댓글 쓰기
    12. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 12 단계, 이미지 3개 중 1개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 12 단계, 이미지 3개 중 2개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 12 단계, 이미지 3개 중 3개
      • Use the Phillips #000 screwdriver to unscrew all five screws.
      댓글 쓰기
    13. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 13 단계, 이미지 2개 중 1개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 13 단계, 이미지 2개 중 2개
      • To uninstall the motherboard, use the metal spudger tool to lift it out of the device.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Tatiana Schneider
회원 가입일: 10/04/15
599 평판
안내서 4개를 작성함
1가이드 댓글
You are amazing!! Please make the tutorial "how change ASUS ME170 Touch Screen Digitizer". Thanks!!!
Walter Tejerina - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 34
전체 시간: 3,758
