주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus PadFone S Front Facing Camera Replacement
필요한 것
  1. Asus PadFone S Front Facing Camera Replacement, Remove the Back Panel: 1 단계, 이미지 1개 중 1개
    • Place your thumb in the charging port and pry the back cover off of the phone.
    댓글 쓰기
  2. Asus PadFone S Front Facing Camera Replacement, Remove the Back Panel: 2 단계, 이미지 2개 중 1개 Asus PadFone S Front Facing Camera Replacement, Remove the Back Panel: 2 단계, 이미지 2개 중 2개
    • Remove all screws using the T5 Torx screwdriver
    • Lift the back panel off the phone.
    댓글 쓰기
  3. Asus PadFone S Front Facing Camera Replacement, Remove the Battery: 3 단계, 이미지 2개 중 1개 Asus PadFone S Front Facing Camera Replacement, Remove the Battery: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Disconnect the battery from the logic board using tweezers
    • Using the plastic opening tools, lift the battery up from its slot
    • Apply consistent, steady force to lift the battery from its slot. Be careful not to damage the battery while removing it.
    댓글 쓰기
  4. Asus PadFone S Front Facing Camera Replacement, Front Facing Camera: 4 단계, 이미지 3개 중 1개 Asus PadFone S Front Facing Camera Replacement, Front Facing Camera: 4 단계, 이미지 3개 중 2개 Asus PadFone S Front Facing Camera Replacement, Front Facing Camera: 4 단계, 이미지 3개 중 3개
    • Once the Battery has been successfully removed, move on to the step 2.
    댓글 쓰기
  5. Asus PadFone S Front Facing Camera Replacement, Start of Logic Board Removal: 5 단계, 이미지 2개 중 1개 Asus PadFone S Front Facing Camera Replacement, Start of Logic Board Removal: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Disconnect the marked strips from the logic board using the tweezers.
    • Applying too much force may damage the strips/connectors.
    • Remember to remove speaker connection located at the bottom left hand corner.
    댓글 쓰기
  6. Asus PadFone S Front Facing Camera Replacement, Logic Board Removal - Continued: 6 단계, 이미지 2개 중 1개 Asus PadFone S Front Facing Camera Replacement, Logic Board Removal - Continued: 6 단계, 이미지 2개 중 2개
    • Disconnect the other two strips that connect the logic board to the phone.
    댓글 쓰기
  7. Asus PadFone S Front Facing Camera Replacement, Remove The Camera: 7 단계, 이미지 2개 중 1개 Asus PadFone S Front Facing Camera Replacement, Remove The Camera: 7 단계, 이미지 2개 중 2개
    • Turn over the logic board to locate the front camera.
    • Grasp the sides of the camera with the tweezers and carefully remove the camera from the logic board.
    • Applying to much force will damage the connective strip.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Everette Gonsalves
회원 가입일: 10/23/14
26 평판
안내서 1개를 작성함
UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S6G1
3 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 24
전체 시간: 1,817
