주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus Q525U CPU Fan Replacement
필요한 것
  1. Asus Q525U CPU Fan Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Asus Q525U CPU Fan Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Asus Q525U CPU Fan Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Begin by powering off the device and flipping the device over.
    • Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
    • Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
    댓글 쓰기
  2. Asus Q525U CPU Fan Replacement: 2 단계, 이미지 3개 중 1개 Asus Q525U CPU Fan Replacement: 2 단계, 이미지 3개 중 2개 Asus Q525U CPU Fan Replacement: 2 단계, 이미지 3개 중 3개
    • Use an opening pick to separate the back cover from the device.
    • For easiest removal, begin by prying at one of the front corners and sliding the tool under the cover in a counter-clockwise motion (to the left) toward the laptop hinge.
    댓글 쓰기
  3. Asus Q525U CPU Fan Replacement: 3 단계, 이미지 3개 중 1개 Asus Q525U CPU Fan Replacement: 3 단계, 이미지 3개 중 2개 Asus Q525U CPU Fan Replacement: 3 단계, 이미지 3개 중 3개
    • Once the cover has been separated from the device, carefully lift the back cover off the device (begin by lifting from the front of the cover first).
    • The back cover should be easily removable, allowing full access to all of the internal components.
    댓글 쓰기
  4. Asus Q525U CPU Fan Replacement, Battery: 4 단계, 이미지 3개 중 1개 Asus Q525U CPU Fan Replacement, Battery: 4 단계, 이미지 3개 중 2개 Asus Q525U CPU Fan Replacement, Battery: 4 단계, 이미지 3개 중 3개
    • The battery of the device is outlined in red.
    • Using a Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery in place.
    댓글 쓰기
  5. Asus Q525U CPU Fan Replacement: 5 단계, 이미지 2개 중 1개 Asus Q525U CPU Fan Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Halberd Spudger
    $2.99
    • Using the Halberd spudger, carefully lift the battery connector up to disconnect it from the motherboard.
    댓글 쓰기
  6. Asus Q525U CPU Fan Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the battery out of the frame to remove.
    댓글 쓰기
  7. Asus Q525U CPU Fan Replacement, CPU Fan: 7 단계, 이미지 1개 중 1개
    • The CPU fan of this device is outlined in purple.
    댓글 쓰기
  8. Asus Q525U CPU Fan Replacement: 8 단계, 이미지 3개 중 1개 Asus Q525U CPU Fan Replacement: 8 단계, 이미지 3개 중 2개 Asus Q525U CPU Fan Replacement: 8 단계, 이미지 3개 중 3개
    • Using a Phillips #1 screwdriver, remove five screws from the fan and heatsink.
    • Remove one 3 mm Phillips #1 screw on the side of the CPU fan.
    • Remove four 2 mm Phillips #1 screws from the heatsink.
    댓글 쓰기
  9. Asus Q525U CPU Fan Replacement: 9 단계, 이미지 2개 중 1개 Asus Q525U CPU Fan Replacement: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Halberd Spudger
    $2.99
    • Use the Halberd spudger to carefully disconnect the bundled slide connector that connects the CPU fan to the motherboard.
    • To disconnect it safely, use the pointed tip of a spudger to carefully push on each side of the connector.
    댓글 쓰기
  10. Asus Q525U CPU Fan Replacement: 10 단계, 이미지 3개 중 1개 Asus Q525U CPU Fan Replacement: 10 단계, 이미지 3개 중 2개 Asus Q525U CPU Fan Replacement: 10 단계, 이미지 3개 중 3개
    • Carefully remove the thicker black cord from the cord clips surrounding the fan.
    • Remove the fan from the device.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Stewart Crandall
회원 가입일: 02/22/22
613 평판
안내서 5개를 작성함
Clemson, Team 2-5, Hunter Spring 2022 Clemson, Team 2-5, Hunter Spring 2022 회원
CLEM-HUNTER-S22S2G5
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 28
전체 시간: 829
