주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus ROG G20CB Graphics Card Replacement
필요한 것
  1. Asus ROG G20CB Graphics Card Replacement, Fan: 1 단계, 이미지 2개 중 1개 Asus ROG G20CB Graphics Card Replacement, Fan: 1 단계, 이미지 2개 중 2개
    • Remove each of the two 4.6 mm Phillips screws on the top and bottom of the tower.
    댓글 쓰기
  2. Asus ROG G20CB Graphics Card Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the front panel to the left and lift gently.
    • There is a cable connecting the panel to the computer. Handle it gently and avoid straining the connected panel.
    댓글 쓰기
  3. Asus ROG G20CB Graphics Card Replacement: 3 단계, 이미지 1개 중 1개
    • Disconnect the cable carefully by pulling gently on both sides of the connector.
    댓글 쓰기
  4. Asus ROG G20CB Graphics Card Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the five 4.6 mm Phillips screws holding down the fan tray and then pull the fan tray out of the system.
    • The fans are connected by a thin cable, be gentle when removing tray.
    댓글 쓰기
  5. Asus ROG G20CB Graphics Card Replacement: 5 단계, 이미지 1개 중 1개
    • Carefully unplug the two fan cables from the motherboard by pulling straight up from the base of the connector.
    댓글 쓰기
  6. Asus ROG G20CB Graphics Card Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the six 4.6 mm Phillips screws connecting the fans to the fan tray.
    댓글 쓰기
  7. Asus ROG G20CB Graphics Card Replacement, Graphics Card: 7 단계, 이미지 1개 중 1개
    • Remove the three 4.6 mm Phillips screws from the graphics card housing.
    댓글 쓰기
  8. Asus ROG G20CB Graphics Card Replacement: 8 단계, 이미지 1개 중 1개
    • Pull the graphics card housing out of the case.
    • Be mindful of the 8-pin power cable connected to the graphics card.
    댓글 쓰기
  9. Asus ROG G20CB Graphics Card Replacement: 9 단계, 이미지 1개 중 1개
    • Push down the clip on the red cable connector and firmly pull the cable from the graphics card.
    댓글 쓰기
  10. Asus ROG G20CB Graphics Card Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the 3.7 mm Phillips screw from the graphics card and its housing.
    댓글 쓰기
  11. Asus ROG G20CB Graphics Card Replacement: 11 단계, 이미지 1개 중 1개
    • Slide the graphics card out of the housing.
    댓글 쓰기
  12. Asus ROG G20CB Graphics Card Replacement: 12 단계, 이미지 1개 중 1개
    • Use one hand to bend up the PCIE riser clip, then with the other hand push it off the graphics card.
    • This riser will need to be used with the new graphics card in order to be installed in this system.
    댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
AdamGadd
회원 가입일: 03/21/25
349 평판
안내서 2개를 작성함
UMass Dartmouth, Team 3-3, Botvin Spring 2025 UMass Dartmouth, Team 3-3, Botvin Spring 2025 회원
UMASSD-BOTVIN-S25S3G3
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 12
지난 30일: 57
전체 시간: 619
